- Joined
- Jan 25, 2008
- Messages
- 16
- Points
- 1,503
Re: Share experiance on 4AGE engine
wonder if the sound really give problem to engine?
thanks.
thanks.
thanks.
Yupp, the Air Fuel is lean, mean not enough oil. A bit worry also ya.
Totally agree with you! If like that i already bankrupt long time ago! I dun think any human can know the AFR reading by listening to engine sound! Thats absurd!how do you know the AFR is lean? Do you measure the AFR with Wideband sensor before? Do you know how to read AFR reading from wide band sensor?
You don't even ask what ecu he running and what other item that he added in to alter the fuel map you already conclude that it's running lean.
That what is the purpose of wideband sensor? just drive a car to you and let and let u hear the sound u already can know the AFR? The how all this tuner going to cari makan since u can judge the engine AFR by listen to the sound of the engine.
Alot of misleading information in this topic. Please do your homework fore posting anything technical.
Bro Scomatic thank ya for your response..
thanks also to Bro EG9..need to confirm AFR level through wideband sensor ya..will looking fwd correct person to do calibration/tuning..![]()
oil that guy means the fuel la toklah..org melayu miyak itam pn pggil miyak,myk petrol pun pggil myk..haha..
what size pipe for 4age 16 valve?
hi,need some help from 4age sifu.im using svt mt,when i depress d pedal,my engine got 'tak tak tak'sound.Is tis knocking sound?How to solve it?Im using ron 97.Y when my rpm reach around 3k,i feel some lag like no fuel?Thanks
:sleep:
