marsha1l_v6
i did retrofit on my headlight too using marimoto mini H1. Right side is parallel with ground. Left side slanting a bit towards the right. so left side cut-off line will be slightly higher. Maybe the lens were design like that because when i test it naked headlamp(without the cover) both parallel with ground.Greetings,
I'm new here and got one question.
I'm using a Perdana and recently just installed the Projector Headlamp, I know how to adjust the lighting Up and Down but how to adjust it Left and Right, because my left side lamp is projecting little bit to the left not center as compared to the right lamp
Feedback is appreciated.
Thanks.
Yes you can adjust up down and left right if you are using original one.
