- Joined
- Oct 31, 2006
- Messages
- 1,394
- Points
- 1,648
Hey guys, recently i heard water boiling sound from engine..and when i hear it closely, it was from the radiator inside...
my engine was 4g93t, there was a spare radiator water tank just beside the radiator, and the water is consuming very fast...around 2 days and the spare tank water dry...but the radiator stil got water inside, and it was full..Additional information tat i wasn't using any coolant from the day i drive my car until now...and the problem only arise few days back..
from the meter panel (not sure if it is working properly or not), the temperature was stil below half...wit air-con, the temp. is at half...
i've check the radiator cap, 0.9 bar standard cap, and the cap stil working properly, means the spring is stil functioning without jam...there is no leaking at all too...
wat could be the possibility of causing the water to boil and is there any negative effect cause to my engine? so wat shud i do to prevent all tis thing happen?
Mistake correction - 0.6bar cap to 0.9bar cap
