Apache91120
Recommended for all ABS, disc and drum brake systems as well as hydraulic clutches requiring DOT 3 and DOT 4 fluids
Provides corrosion protection for all metals within the braking system
Compatible with all conventional brake fluids
Substantially reduces the possibility of fluid vaporization and eventual brake failure
Excellent performance in high-temperature braking systems
Prestone synthetic brake fluid provides corrosion protection for all metals within the braking system and meets or exceeds DOT 3 and DOT 4 specifications, for excellent performance in high-temperature braking systems. This formula substantially reduces the possibility of fluid vaporization and eventual brake failure (as a result of vapor lock) by maintaining a high wet boiling point. Recommended for all ABS, disc and drum brake systems as well as hydraulic clutches requiring DOT 3 and DOT 4 fluids. Compatible with all conventional brake fluids.
MADE IN USA.
TEL: 012-9154001
MADE IN USA.
TEL: 012-9154001
