Apache91120
Overview
Prestone® Power Steering Fluid for European Vehicles is a premium full-synthetic formulation specifically engineered for European Vehicles including, BMW, Mercedes-Benz, VW/Audi and all other European manufactured vehicles. This formula is designed for extreme temperatures while also providing excellent low temperature operation. Helps protect against wear, foaming and corrosion to maintain optimal performance and deliver excellent oxidative stability for extended fluid life. Suitable for use where Pentosin CHF 7.1, 202 or 11S fluids are recommended.
Premium full-synthetic technology with the newest additive chemistry, designed for extreme temperatures and extended fluid life.
Provides protection against wear, corrosion, fluid breakdown and foaming to maintain optimal performance.
Suitable for use where CHF 7.1, 202 or 11S fluids are recommended.
1.5 times the oxidative stability (fluid breakdown resistance).
Engineered for BMW, Mercedes, VW/Audi, Porsche, Saab, Volvo, Jaguar, Mini, and Peugeot.
Instructions
With Engine off, wipe power steering reservoir filler cap area clean and remove cap. Fill reservoir to specified level. Do not overfill, check regularly and refill as needed. After using product, always wash exposed skin thoroughly with soap and water.
We recommend you change your power steering fluid every 2-3 years or 48,000km - 96,000km.
Technology
This formula is designed for extreme temperatures while also providing excellent low temperature operation while protecting against wear, foaming and corrosion to maintain optimal performance and deliver excellent stability for extended fluid life. Suitable for use where Pentosin CHF 7.1, 202 or 11S fluids are recommended.
MADE IN USA.
TEL: 012-9154001.
Instructions
Technology
MADE IN USA.
TEL: 012-9154001.
