brooo what i know is 6A12tt have 2 model
1.ETERNA GRADE XX-4
Grade XX-4, produced from 1993 (october)
Add to comparsion list
GENERAL
Body type Sedan
Drive FULL 4WD
Transmission Fuzzy shift 4 speed full automatic (hold mode you attach) the
Displacement, cc 1998
Frame E-E84A-PRXF
Price of new car, thousands yen (Tokyo area) 3405 (~$28300)
SPECIFICATION (SPECS)
EXTERIOR
Exterior dimensions (LxWxH), mm 4610 x 1730 x 1405
Interior dimensions (LxWxH), mm 1890 x 1450 x 1160
Wheel base, mm 2635
Treads (F/R), mm 1510 / 1505
Ground clearance, mm 160
Curb vehicle weight, kg 1460
Gross vehicle weight, kg
Seating capacity, persons 5
Doors number 4
Min.turning radius, m 5.3
Fuel tank capacity, l 64
ENGINE
Engine model 6A12
Max.power (Net), kw(PS)/rpm 215 ps (158.13 kw) / 6000 rpm
Max.torque(Net), N*m(kg*m)/rpm 31.5 kg*m (308.91 N*m) / 3500 rpm
Power density 6.79
Engine type V type 6 cylinderDOHC24 valve IC twin turbo
Engine information
Fuel system ECI-MULTI (electrically controlled gasoline injection)
Turbocharger Twin Turbo with intercooler
Fuel type Unleaded premium gasoline
LEV system (Low emission vehicle) No
Compression ratio 8.5
Bore, mm 78.4
Stroke, mm 69
Final gear ratio
Fuel consumption at 10-15 modes, l/100km 10.4
Fuel consumption at 60 km/h, l/100km
CHASSIS / TRANSMISSION
Power steering Yes
Tires size, front 205/60R15 91h
Tires size rear 205/60R15 91h
Braking system, front Ventilated disk
Braking system, rear Ventilated disk
Suspension system, front Multiple link type
Suspension system, rear Multiple link type
2.GALANT VR 4 SType(manual)
Grade VR-4 S type, produced from 1993 (may)
GENERAL
Body type Sedan
Drive FULL 4WD
Transmission 5 speed manual
Frame E-E74A-SNGF
Price of new car, thousands yen (Tokyo area) 2803 (~$23300)
EXTERIOR
Exterior dimensions (LxWxH), mm 4630 x 1730 x 1410
Wheel base, mm 2635
Curb vehicle weight, kg 1410
Doors number 4
ENGINE
Engine model 6A12T (twin turbo intercooler)
Max.power (Net), kw(PS)/rpm 240 ps (176.52 kw) / 6000 rpm
Power density 5.88
Engine information
Bore, mm 78.4
Stroke, mm 69
Final gear ratio
Fuel consumption at 10-15 modes, l/100km 9.8
3.GALANT VR 4 S-TYPE(auto)
GENERAL
Body type Sedan
Drive FULL 4WD
Frame E-E74A-SNGF
EXTERIOR
Wheel base, mm 2635
Doors number 4
ENGINE
Power density 5.88
Engine information
Bore, mm 78.4
Stroke, mm 69
Final gear ratio
1.ETERNA GRADE XX-4
GENERAL
Body type Sedan
Drive FULL 4WD
Frame E-E84A-PRXF
EXTERIOR
Wheel base, mm 2635
Doors number 4
ENGINE
Engine model 6A12
Power density 6.79
Engine information
Bore, mm 78.4
Stroke, mm 69
Final gear ratio
Power steering Yes
GENERAL
Body type Sedan
Drive FULL 4WD
Frame E-E74A-SNGF
EXTERIOR
Wheel base, mm 2635
Doors number 4
ENGINE
Power density 5.88
Engine information
Bore, mm 78.4
Stroke, mm 69
Final gear ratio
GENERAL
Body type Sedan
Drive FULL 4WD
Frame E-E74A-SNGF
EXTERIOR
Wheel base, mm 2635
Doors number 4
ENGINE
Power density 5.88
Engine information
Bore, mm 78.4
Stroke, mm 69
Final gear ratio
