New Brand T-shape toothbrush - Multiway Toothbrush
All Other Stuff
harlo
Selangor
[WTS] New Brand T-shape toothbrush - Multiway Toothbrush - a Nice product
[WTS] Multiway Toothbrush
Multiway Toothbrush was rated 99% for product effectiveness while the conventional toothbrush was rated only 37%. This is to prove Multiway Toothbrush is more effective than any other toothbrush.
This toothbrush is an environment friendly product. Besides that, it can effectively clean our outer part of our teeth and inner part of our teeth and makes our teeth more healthier. The most important thing is the soft bristles will not hurt the sensitive gums.
URL]
Why the toothbrush is called Multiway toothbrush?
This is because Multiway Toothbrush, also known as Multi Directional Toothbrush is a detachable toothbrush with replaceable brush head that can be changed into 2 different brushing directions.
The design concept and unique characteristic of the Multiway Toothbrush is to separate the brush head from the handle. The brush head which has 2 different connecting points at 2 different locations can be connected to the handle and can effectively brush the teeth in 2 different directions.
URL]
URL]
URL]
Hence, Multiway Toothbrush is an innovative which is going to replace the conventional toothbrush, because Multiway Toothbrush is more advance than the conventional toothbrush and the special features are as shown below:-
1. More effective teeth cleaning
2. Multi-brushing directions
3. Environment friendly
4. Cost saving
5. Space saving
6. Minimize the tendency for gum injury
7. Enhance the interest of teeth brushing
8. Effectively remove tobacco and coffee stains
9. Easy usage
10. Reduce tooth decay
11. Highest quality bristles (Dupont Nylon 612)
12. Life guarantee on handle
Multiway Toothbrush has been evaluated by a renowned product evaluation company using the computer analysis program. Multiway Toothbrush was rated 99% for product effectiveness while the conventional toothbrush was rated only 37%. This is to prove Multiway Toothbrush is more effective than any other toothbrush.
There are ten special features of this product. What is that ten features?
a) Two Brushing Directions
- The MULTIWAY TOOTHBRUSH has more brushing direction than any other ordinary toothbrush. It can brush your teeth in two difference directions. The T-SHAPE direction is more effective ub brushing teeth and has up to 99% cleaning effectiveness.
b) Easy Usage
- The MULTIWAY brush head can easily be changed within seconds. It is easy to use and the user can control the brushing speed comfortably. Even for longer brushing period, the user's hand will not feel tired. When compared to ordinary toothbrush, it is definitely easier to use and handle.
c) Cost Saving
- When the consumers need to change a new toothbrush, they just need to change the brush head only. The handle can be retained, in a way; they can save the cost inclusive of handle, packing and transportation. Just for an example, a ball pen, purchasing and changing the refill is always more economical than replacing for another new item.
d) Space Saving
- When you purchase a dozen of toothbrushes, you need to have a large storing place. However on the contrary, if you purchase the multi-way brush head, the storage space required is relatively smaller.
e) Environmental Friendly
- If everybody is replacing the old toothbrushes, it can be accumulated into an alarming huge quantity of garbage because there are more than 6 billion populations in the world. However, if we were to replace the brush head only, the amount of garbage produced would be relatively much lesser.
f) More Effective Teeth Cleaning
- When compared to ordinary toothbrush, the MULTIWAY TOOTHBRUSH's cleaning action is more effective, because the MULTIWAY TOOTHBRUSH is specially designed according to the structure and shape of the human teeth. It means that when you use MULTIWAY TOOTHBRUSH to brush the teeth, you can easily control the speed and direction of brushing to ensure that the teeth are properly cleaned up.
g) Interest Enhanced on Teeth Brushing
- When compared with ordinary toothbrush, the user of the MULTIWAY TOOTHBRUSH will feel more enjoyable and relaxed when brushing their teeth. Firstly, the user's hand will not more feel tired even for longer brushing time. Secondly, the user can change the brush head easily at any time. As a result, the user of MULTIWAY TOOTHBRUSH will find that brushing is a more interesting and exciting experience. Unlike conventional toothbrushes, the user will feel that brushing is monotonous and routine. In a way, using MULTIWAY TOOTHBRUSH will induce the interest of frequent teeth brushing and the teeth will become cleaner, whiter, smoother and brighter.
h) Minimize The Tendency of Gum Damage
- When using conventional toothbrushes, it is difficult to control the speed the movement and direction of teeth brushing. As a result, it is very easy to hurt the gum which would result in bleeding. However, on comparison, when using MULTIWAY TOOTHBRUSH the user can easily control the speed, movement and direction of teeth brushing. Therefore, the user will not hurt the gum during brushing. This means that MULTIWAY TOOTHBRUSH will not only clean up the teeth thoroughly, it will also minimize the tendency of hurting the gum as well.
i) Effectively Remove Coffee and Tobacco Stains
- In accordance with our experiments, the MULTIWAY TOOTHBRUSH's brushing action can easily remove coffee and tobacco stains effectively.
j) Highest Quality Bristles (Dupont Nylon 612)
- Dupont Nylon 612 Bristles are high quality and has been approved by the FDA of United States. The shape of the Dupont bristles are round which will not damage the gum.
The difference between the Ordinary Toothbrush and this Multiway Toothbrush...
(Front Teeth)
Ordinary Toothbrush
As commonly known, the correct method of brushing teeth is from up to down. With an ordinary toothbrush, moving up and down to clean the front of the teeth, is unable to balance its movement of brushing, It is also difficult to control the speed. As a result, the hand gets tired and the time of brushing is reduced. Therefore, it is impossible to clean the teeth thoroughly with one directional brushing.
Multiway Toothbrush
T-SHAPE OF Multiway Toothbrush can brush the front of the teeth freely and evently from up to down. It can clean the teeth more effectively up to 99%.
Rear Teeth
Ordinary Toothbrush
An ordinary toothbrush is impossible to clean the rear of the teeth. This is because the design of the ordinary toothbrush disable from up and down brushing the rear of the teeth more freely and evenly. It can only brush the rear of the teeth from left to right, therefore the majority of teeth decay is always from the rear of the teeth.
Multiway Toothbrush
T-SHAPE of Multiway Toothbrush can brush the rear of the teeth freely and evently from up to down. It can effectively remove all the stains from the rear of the teeth.
The price of this product...
RM 19.20 for one set (for pakej) (For more information, you can send me an email : [email protected]).
**One set is include one head of the toothbrush and one handle of the toothbrush.**
++The handle of the toothbrush has Whole Life Warranty with RM 12 ONLY++
+++ The high quality Dupont Nylon 612 bristles which cost RM7.20 Only +++
++++ Later, if you want to change your toothbrush, you only need to change the toothbrush head which only cost RM 6.30 ONLY (if you are a member) +++
+++++ No Membership Fees Will be charged For Whole Life if you become a Member. +++++
++++++ NO any Fees That Needed to become A member ++++++
Besides that, you can join us to sell the Multiway toothbrush and earn some money..
Futhermore, do you
Have the teeth problems ?
Feel hard while brushing your teeth?
Have an uneasy smell even brushing the teeth for twice a day or even more?
Need the teeth treatment for several times?
Have the tooth decay problem?
Got blood while brushing teeth?
After using Multiway Toothbrush, you will NO NEED TO WORRY about the problems anymore..
Talk with confidents everyday and smile always to the surrounding people after using this Multiway Toothbrush..
Don't believe ? You may have a try for it ...
Do you have more interests to our Multiway Toothbrush? Lets come and join us now so that you will have more benefits and earn more money besides can Protect Our Earth and Protect your Teeth.
Dealing method : bank in and delivery by Pos Ekspress / COD
Location of seller : Shah Alam or Subang Jaya
:hmmmm:For further information or for those who are Interesting to the product, you can email to [email protected] or kindly leave a message to me at here. Thank you.
* To enhance your confidence to this product that I have introduced, you can search the website below to get more informations :
1) YouTube - T Shape Toothbrush
2) http://www.densonworldwide.com/en/tb_usage.html# ( Multiway Toothbrush usage instruction )
Got anyone want to buy one set of toothbrush to have a try? There are 15 sets of toothbrush on my hand ..
There are 14 sets more of toothbrushes on my hand. Who have interesting to have one set to try?
Yup. Multiway Toothbrush is a good product.
Do you have interested to buy the Multiway Toothbrush? =)
A best product, a good toothbrush, it can clean your teeth more effectively than ordinary toothbrush. Who are interested to get one or more?
A good T-shaped toothbrush from Denson.. Who do like to have one toothbrush?
new 15 toothbrushes in my hand.. Who wants to have one toothbrush to have a try?
Great news... For celebrating the Hari Raya Aidilfitri, there are a couple sets promotion start from today until the end of 25 September 2009... Do check it out today from me...
Does anyone want to buy one T-shaped toothbrush to try?
Never try, never know...
A good toothbrush !! Environmental friendly, care for your teeth, and much more...
Come and get it One Today...
