Need help
NeniNeniBoBo
Bro, is that normal if oil come out from oil catch tank breathe hole? This happen only during dyno run and rev above 7k.
Is that a lot?Should say normal for most RB especially on high rev. Make sure you always flush the dirt oil remain in the catch tank
Thank you bro for your information. Just little bit oil come out from there. Btw, currently I'm using ARC Oil catch tank but I read from Uk GTROC forum, they said ARC OCT only good in looking but not good in design, is it true? Maybe the OCT hose entrance is too near to the breathe hole and the oil will easy come out from there especially in high rev and affected by G-force while cornering. Anyway, thank you so much bro ^_^
Is that a ARC OCT that replace the windscreen washer tank?Suppose proper installation will make it closed and loop back to engine head.Eg: GREDDY design and CUSCO. Using breath filter/open hole is dangerous.The gas comes out from the cylinder head is easilly to burn and the OCT should be install far from exhaust/turbo outlet (high heat area)
