where is your location?issit possible that the air-con fan din work resulting the air not cool while ur car is stop?
bro hoong,comment a bit la...
yeah.. it could cus by ac or radiator fan didnt work well.. check both fans...how about ur temp level?..
aiya.. damon.. me also know nothing 1.. just ask him bring to my dad shop lo .,,.. much more easily right.. talk here also no use.. hahah
guess the only place to get is chop shop.....
few option he has actually
1) get it from chop shop.. price.. 180-280 also got.. depend on ur luck/fate about the compressor quality.. cus it always expose to water n air into it.. rotary compressor suck... unless u can get the comp which on the halfcut...
2) get a new 1.. this not economic.. cus very very very@#&(@#$%& pricey... but can get it in msia.... NEW
3) Modify the comp into local 4afe compressor(denso=piston type).. which much more cooler than ur stock svt comp.. problem is ur 20V will few a bit heavy and need to redo/ modiry ur ac comp wiring... cus 20V comp got many sensors la.. hahah
Dear all,
Need your help, i just service aircond and change a new APM coil cost Rm230( old one found leaking)
And change a new valve cost RM120, refill 134 Gas, receiver drier (filter) cost RM65.
now problem is when the car stop, air is hot. when running, it turns back normal.
after done all this job, aircond mech told me is the compressor problem. (dunno which one is true???)
need your help to find me compresor used and reliable one.
thanks in advance
how about when ur car stop.. when hot air coming out.. u try to ram ur RPM ntill 3-4k range for few second.. then c c got any cool air come out or not..
yes... compressor weak or heat transfer in engine bay not good
no.. compresor kong or no gas or leaking lo.... haha
just 230 for a coil?????? i think is not original coil from denso la.. APM will not tat good or cold than denso ori coil la..
above statement is base on my own experience .. it might be wrong.. just correct me if there is .. haha
cabutttttttt....................................
