I heard my friend say using the gsr wiring and ecu will give the good response for 4g93p N/A.Is it true?Any ppl done it before? As i know,gsr wiring got the resistor pack for injector.What is the function? I hope all the sifu can give me oppinion.
How about if using the gsr wiring only coz my wiring got problem.What is injector resistor pack use for?
Please do not use the GSR Ecu with your NA. You car will run like crap!! Imagine 4G93T use 390cc injector and 4G93P use 240cc injector. MAF is different, compression also lain and many others. Just get the GSR Wiring if you got wiring problem
Resistor pack is used for the turbo low impedence injectors. Not applicable for you NA.
Similar threads | |
