alamak bro JaHaX, i dont think i deserve to give tutorial lessons la, i myself dont drive skyline. drive old junk only. not on same level with the other skyline owners here. menyibuk a bit here n there can la:wavey:
i have a fren who runs 4wd gearbox on an rb25 engine (yeaps, some surgery needed on the gearbox to lock 4wd mechanism). but the problem is, the gearbox is too big. in a cefiro A31, even small bumps needs to be tackled delicately to avoid the gearbox touching the road. dunno bout ur r32 but i'm guessing same problem will arise...its alot easier to putt in the r33 gtr with r33 gtst ver 2 gear box.. less complication.. can put in the 6 speed but need to mod the gear box to make it rwd..
it is not street illegal, its just not practical. anyway its not my car, its my mate's car. my car is much much older than A31... can consider junk already heheWould that mean your A31 is street illegal?
From what i can see here if compare to my previous R34 GTT, R33 GTR and my current R34 GTR. If you wana put in an 4wd box into and non GTR body. Your car need to be knock on the fornt left gearbox side. The best is, put both car on hoex and you will see the different. Else then that from my recall i dont think there is much modification.
But pls dont used R20 5speed box into RB26 engine, the gear ratio is too short. example: 5th gear RPM 6000 plus on 180KM/H. My 6 speed box, 4th gear 180km/H. imagine the different.
"Make it old junk or Skyline, is what you master at we seek." Anyway, I do found a lot of guy who know a lot about Skyline spec and technically more than a Skyline owner itself. It's the passion.
R20? Is that a gearbox type or just a typo error?
so, KFM, when is ur 4 door comin out? come join the "pakciks" club..hahahahaha.. we go for golf, cruisin on the Ring, hehehehe
the prob is the foward transfer case. only the bnr or 4wd chassis have that hump on the chassis.. or else its gonna hit the body..
Best bet is to match with the 25 manual gearbox
As far as I know, for the 4WD gearbox, once you un-hook the attesa unit, the box basically runs like a RWD-mission.
The problem (HUGE) only if you want to make it 4WD which means, you'll need the abs module, attessa/abs ecu, attesa/abs loom, attesa pump, plumbing/lines, relays, modules, sensors and whole lots of fairy-princess potions that you don't hop up zillion error codes
Basically, I do have all the mentioned in one of my room and practically spend time carassing the secrets out of them ... :hmmmm:
What about using the r33gtr 4wd setup? can this be done ?
would like to try this in my hc35 as i know it has less electronics than the r34gtr
Here is the tweeter..pioneer TS-T35
it's an old model actually..very2 ol skool...
