~ my iswara ~ ^^
there's a kind of powder, which u put nearby to where the ants move around, and the ants will take the powder, back to the ants nest, and eat, and the whole gang dead. i saw my dad used before. but not sure where to get.
kweng84 said:
Dog bite it? your dog dont have anything to bite but bite sensors ar?? hmm...i wonder if u still left your side signal light with you... lol :) my dog not interested with anything from my car besides go urine on my rims and bite some cats till dead (this month alrealdy second cat died..sigh)
My dog very naughty de. Before i send my car to repaint, my dog already bite my car fender, rear bumper and mudflap. My dog like to pee on my rims also. When i park in only, he sure busy start peeing. I had install the electro static at my rear bumper and end up give dog bite liao.,.. 1 day jao waste rm50. If i put reverse sensor, i guess more teruk.. Hehe..
kweng84 said:
haha;) really 'naughty' la...
Sometime feel wanna kill him nia.. Hehe..
I wanna ask something.. How to increase car top speed? Everytime i when change to gear 5, i can't speed over 130km/h. In 139km/h using gear 5, already go 3k rpm. Any solution can make until can fly until 180km/h?
did u do any modification on ur engine ??
is ur air cond on when u r testing ur car ?
u try it on day time or night time ?
try do it at test it at night time la more cold air will produce more osigen thus will create more power in da engine
khen: 4-1 extractor ar? stock iswara already 4-1 wor..why still seeking for 4-1 ? ;) u mean u want bigger size 4-1 izzit? pm me...
singchaii: my 4th gear also reach 130km/h liao wor...but my top speed not good also one la..180km/h no way for me..maybe take very long time...
whoa.... cruel tactic.... i like it...
the powder called what??... wanna put oledi... kasi bunuh all ants 9 9.... muahahaha...
tomolo go hardware shop buy....
lolz.... coz ur dog also likes u car alot mah... dogs like to pee at their territory...
u din buy dog bone let him bite meh??... so desperate wanna bite ur mudflap... hahaha.... mayb coz got KFC taste....
139kmh @ 3k rpm.... not bad wor... what gearbox u using??...
coz normal 4g13 gearbox, 120kmh usually at around 4k rpm ler....
i've tried doing 160kmh in my car la... rpm was around 5k rpm... hahaha... no balls wanna go faster la... suspension also damn cialat, not specific for top speed....
for topspeed setup, get 4-2-1 header, midbullet, and s-flow muffler lo...
if wanna maintain ur straight flow muffler, change ur midbullet to s-flow geh....
in short, back pressure helps ur top speed....
Sorry brother. Typo error.. It is 130km/h in 3k rpm.. I jz using standard stock. No any modification have been made on my iswara.. But recently i jz sent my car to service, i can fly to 140km/h with 3.5k rpm. Only that day finish service can speed to the 140km/h. After than that, no more liao..
Sometime when wan potong people car in speeding, i need to rewind down my door mirror and switch of the air cond only can potong car >_<.
My 4th gear only ngam ngam can reach to 100km/h only.. So sad.. If 4th gear can reach 130km/h, then ur 5th gear mai can touch to 160km/h? Nice ler..
if he revs his first gear until 6k n so does the following gears... i think reaching 130km/h by only 3k is not a problem at all...
cheeers
Sometime when wan potong people car in speeding, i need to rewind down my door mirror and switch of the air cond only can potong car >_QUOTE]
hey...how come ur stock gear box can reach 130km/h @ 3k rpm one? my stock can only reach 110km/h @ 3.5k rpm.
I'm riding a 1.3 carb manual la...what's ur engine? 1.5 ar? maybe 1.5 has different gear ratios.
1.5 and 1.3 same gear ratio mah...
unless like theorekz said, mayb he drop gear and rev till redline, his 130kmh could be at 3.5k rpm....
if same gear ratio, then no matter what rev u use, there's always a specific speed for that particular rpm at that particular gear.
what is mentioned here is 130km/h @ 3k, which i assume to be in gear 5 at least. in which i can never achieve that. my 110km/h in gear 5 already reached 3.5k rpm.
http://www.eon.com.my/article.cfm?id=64 this is the spec that i found.
I don't know wow.. I really can speed 130km/h at 3k rpm or sometime 3.5k rpm. Didn't try 130km/h over 3.5 rpm even 1 times.. But my 4th gear go 100km/h at 3k rpm also..
Mean standard gear box can make 130km/h at 3k rpm? My car can mean got problem ark?? >_< But my car at 130km/h already top.. Press the whole acceleter also at 130km/h only..
singchaii how cm ur car so weird 1 ?
so r sayin ur car maximum speed is 130km/h at 5th gear at 3k rpm ?
my car 100km/h at 5th gear alrd 3k rpm but my top speed is around 150km/h like tat coz i change my flywheel my top speed gone
n singchaii ur 4th gear can onli reach 100km/h ? the max ?
y not u try wat therex said that u change ur every following gear at 6k rpm and let us know after u tested
i am wondering is it a secondhand car? if it's a secondhand car, then it should have been mod by previous owner.
and 130km/h max? erm...normally in gear 5 to speed up more than 130 is possible one. how come u cannot? erm...ok...one possible thing is ur engine oil. servicing. i'm afraid ur engine is a bit clogged.
really confused about ur car la, SingChaii.
theorekz: yeah, u r right. That day in highway my 4th gear tarik until 6krpm at about 130km/h and then 5th gear tarik from 3.5krpm like dat...
