MonsterTacho said:henry: 8000rpm and above still need to tune ar? whats your maximum rev? 9k?
re-program your chip again?
im still thinking of getting a VAFC2, however, Thomas told me
dat piggybacks cannot add fuel, it can only decrease fuel and channel the fuel elsewhere.
as for me, after analyzing my a/f ratio, the afr drops after 6k rpm. i wonder if its time for a
slightly higher cc injector or a higher flow fuel pump. i understand that my fuel pressure is
quite high at the moment.
But, i do not want the piggyback to over-ride the re-chipped specifications. do u think it
will?
speedking said:henry, can make the chip perform 100% with out the piggyback?
i personally drove henry's car b4...i dun trust the dyno machine is giving the correct figure...
based on my dyno chart...my fuel is very rich....shit la like that..petrol price is increasing la, still my car want to run rich...
and henry, after plug in ur ECU...does the fueling become better?
MonsterTacho said:speedk: what do u mean u dont trust the dyno machine? i heard some places your hp figures higher, someplaces lower hp la...
Henryfong said:DYNO result ....
AhLoon => 138.7
Speedking => 137.5
MonsterTacho => 166.8
Hyperreved6313 => 166.7
02100 Yap => 142
Quite disappointed for my result ... nvm ...
mirage901 said:Wah, thats the result...thats great wei.
Hope my auto mivec can at least reach 130++ on wheel..
Btw got any chip to add on my mivec ecu ar?
Henryfong said:sorry .. cant help u on this lar.... last time my friend got 1 ralliart computer box for ur range of mivec ... i did try his car ... not much different ... n not that powerful ... .unless u can get mine's one lar ....
Anyway how is ur car now ...??? still in hopitalized ar????? i need to check ur air fuel ler ...
mirage901 said:The other day u mention that my mivec can change the current ecu back to the early type...
Hows the outcome after changing it?
Henryfong said:Kenny .. i cant confirm with that ..... need to do experimen on that ... cant confirm 100% ...
but from i know somebody convert it b4 ... .
\\speedking said:dunno this will help or not...but last time my ECU kong that time, my mech found a Gen2 mivec ECU...but the pin cannot fit in...
MonsterTacho said:before i forget...
is there a difference when you dyno your car on a 2wheel dyno machine (like gtauto) as opposed to a 4 (front and rear) dyno machine (like in speedworks) ? ive heard that there are some dyno machines out there which give substancially different hp figures than others. but then again, its hearsay.
any comments?
jzhost said:sorry just wanted to know, this had been discuss last time i couldnt find.
for mivec box, 5th gear 3k rpm will at how many kmh?
