Microtech
17)microtech turbo timer
bro can discribe more about this microtech turbo timer..??
thanz
End of this month have one Microtech tunning course, hear about that is microtech boss come to train. Need more detail pls contact Joshua (0123205454).
Microtech MT8 ECU
guys.. wanna ask whether MT8 is compatible wit LT8 ? i don see MT8 on microtech's site for i guess its an older model.. i need the support file n diagrams.. any site can help me out wit this or is MT8 compatible wit any Microtech ECU inna market now ?
guys.. need an answer here. if lets say i buy a 2nd hand microtech, n previously it was used on a diff car, do i need to 'format' it n repogram it again? or just plug n then tune it... thanks~
i think when u plug n tune it its consider as reprogram back again i think.. so just the same
oooo.. so i can just buy a 2nd hand LT10 then go to milenium motorsport n tune it there???
handsomeboy,
if i'm not mistaken.. if the car model have a sequential fire same as previous model. so it can be use. no need to reprogram it just need to retuned it.. means like this arr.. proton n mitsu engine can share same microtech management but rotary n boxer cant.... hehehe... sorry if wrong info.
ooooo... ok ok. im using a proton neo, how? well, the easiest way i to buy a new one which can be very expensive...
wow...proton neo wanna use microtech. heavy mod already? just a suggestion, microtech cost a bomb, if ur car in stock conditon or normal mod, i suggest go for a piggyback such as emanage or safc... should be enuf already, unless ur car is heavy mod then u can consider a microtech. no offense bro... even me still using a piggyback even thou can be consider my car is heavy mod already. no money arr bro...
yeah i also heard microtech from rx7 cannot use in inline 4 engine, but im not sure, u have try to double check with millennium motorsport.. but from same inline 4 engine still can be use i think...
hahaha.. i know, usually heavy modded car running standalone. hmmm, ill do this after i do the internals n all. like PnP, change piston etc...then only i will consider microtech. cuz i think the 'brain' of the car is the most important. thats why i wanna use this really intelligent brain :) hehehe.. n FYI bro, e manage costs like 2k++.. i think better i save another 2k n i can get my hands on microtech already. n i dont think SAFC or emanage is compatible with SIEMENS EMS 700..
good to hear your idea.... no need to have headache after install microtech... all thing your neo want to mod should be no problem after dat... from small thing to big one.... gd luck on ur project
yeah, true.. cuz the brain is already intelligent. n thanks~ if ur having a project of ur own, good luck too..
guys.. i wanna ask something. i heard from a source that for standalone ECU like microtech, etc, have to tune it regularly? like every 3 or 4 weeks have to tune again? or if i disconnect the battery, then have to go tune again??
r these 'rumors' true?? hope the sifu's can help me answer... thanks!
no need to tune, just tune it for one time, u just need to retune it if u do some modification or want to change ur car setup such as track setting to drag setting
Just wondering, if the throttle response is extremely bad and the car feels heavy, is that something to do with the tuning?
oooooo.. okay okay.. hmmm cuz someone told me have to retune every 4 weeks like that... so now its clear that only need to tune once.. unless if wanna change anything. thanks again~
