kennethfong said:any recommendations???? i've called joshua b4 bout mt4, any other options i have??
also i heard microtech is not that good in air cond idling, is this true???? n haltech/motec is too expensive, MS not reliable, power fc doesn't have the default map for my engine, hks fcon dunno, what should i be looking for?
i want a smooth ride but not forgetting power at the same time, means air cond on and off during idling must be rock solid stable!!
cheers
Who told you that MS is not reliable? When it comes to tuning, it's the tuner's responsibilities, not the hardware. I'm using it with no issues.
If you want a stock type rock solid idle when using air-cond, I think don't even dream of changing your stock ecu. Stock is still the best. Not even the most expensive aftermarket ecu can give you that kind of stability for idle with air-cond 'on' at idle. They are aimed for performance. But it can be done. Just don't compare to stock.
It's not a good idea for people like you to start changing parts or mods either. That will screw up things which are frustrating sometimes. Keep everything stock and you should be fine. Whatever it is, if you want to have more info on what I have in hands, gimme a call. We can always discuss.
