- Joined
- May 20, 2006
- Messages
- 68
- Points
- 1,506
Hi guys , I got a problem with the lmst meter-THe meter does not function when i switch on .Only works when i Turn on headlight -When insert key turn to ACC it does not work no indicator light -if i start like that the meter wont work all the indicator including rpm wont work - i have to switch on headlight and off for it to work -
Another thing i find it difficult to start normally will kick with one turn now difficult-then i tested by switching headlight on and starting -work with one turn-short turn ignition on.
Any of u guys wo using lmst had this problem before-Wat is the solution ? any idea guys ..I took the meter and checked looks more like some relay or wiring problem -
i also checked the wiring but so far no luch finding the issue - not really sure wat wrong -when was in warranty period this happend onc ebut protong some how fixed it - dono how they did it but this prob come back again
Guys if u know please share
