jun3 cam spec?
thanks bro walbro...but i found it the duration is 304...why some are 265.3 n some are 304? is it a different stage?i just wan to confirm which 1 is true...
this is @1mm reading
Thats the thing, until now i dunno how to read cam specs... some say like this, some say like dat... :confused:
anybody can clarify??
yeah, i've been trying to learn more about this, at least next time when i have the $$$s, i know which cams I should go for..
304 is at 0mm lift, 265.3 is at 1mm valve lift. Jun always advertise at 0mmlift. Toda adrtise at 1mm lift.
urbanracer
urbanracer
lift for which one, intake or exhaust? at what RPM? this is what most of us here wants to learn, so that next time we can read the specs of the cams and know which one is the best for our requirements..
urbanracer
yeah!u right.jun 3 is very good race pack.hehehehe
use the internet: http://www.allmotorhonda.com has the best b series cam specs i have ever come across.
besides the lift and duration, u would want to look into the cam lobes ramp angle and overlap period. Although the overlap period can be adjusted using adjustable cam gears, these 4 factors basically determines whether which cams are suitable for your engine.
cams with low ramp angles are easy on the valvetrain, but gives a little less power, vice versa. High overlap period good for top end power, but sacrifices the low and midrange power.
cams like buddy club 3 has very nice paper specifications but only perform a little better than type r cams, because of the ramp angles and overlap timing. the lift and duration should only be used as a rough estimate of what u r lookin for, and not the ultimate deciding factor in looking for cams.
urbanracer
