Interested: Call 012 227 8324
Ready Stock Available
Package Includes:
Jetbeam Flashlight
Ultra Fire Charger with 2 Rechargeble Batteries
Nylon Sheath
Model: RRT-2 (R2)
Specially designed for Military, Law Enforcement, Search & Rescue and Outdoorsman
The Rapid Response Activation Ring allows the user to select between the three various brightness levels and strobe function.
Stainless steel Rapid Response Activation Ring, increased reliability and durability.
Features JETBeam's new randomizing strobe--"Strobe Randomizer", taking strobe to a new level.
Stainless steel bezels protect the head and tail cap from drops and impacts.
Stainless steel crenulated bezel can be used as a glass breaker or defensive tool.
CREE XR-E R2 LED
Max output of 240 Lumen with an effective range of 300+ yards
New hybrid reflector specially designed for CREE LED, which allows for better beam quality, efficiency and throw capability.
Features a redesigned high efficiency broad voltage drive circuit.
Compatible with both CR123 batteries and 18650 rechargeable Li-ions.
Floating positive end, designed for better battery contact.
Built-in intelligent Li-ion rechargeable battery protection circuit.
Impact-resistant meets US MIL-STD-810F accords.
Meets IPX 8 waterproof standards
RRT-1 Raptor can utilize the "RM-01" tactical pressure switch and other available accessories, which allows it to be used for a variety of missions.
Dimension: Head Diameter 35mm, Tube Diameter25.4mm, Total Length 145mm
weight: 175g
Output & Runtime:
High Mode
Using 2*CR123 batteries: 240 Lumens, 2 Hours
Using 2*16340 batteries: 240 Lumens, 1 Hour
Using 1*18650 battery: 240 Lumens, 3 Hours
Mid Mode
Using 2*CR123 batteries: 100 Lumens, 6 Hours
Using 2*16340 batteries: 100 Lumens, 3 Hours
Using 1*18650 battery: 100 Lumens, 8 Hours
Low Mode
Using 2*CR123 batteries: 30 Lumens, 20 Hours
Using 2*16340 batteries: 30 Lumens, 10 Hours
Using 1*18650 battery: 30 Lumens, 25 Hours
Package Includes:
Jetbeam Flashlight
Nylon Sheath
Model: RRT-2 (R2)
CREE XR-E R2 LED
weight: 175g
Output & Runtime:
High Mode
Mid Mode
Low Mode
