how to install AFR??
WAJA2003
Shah Alam
Hmmm do anybody know install AFR meter??
I ask at soem workshop they cost me RM80 wohh...
i hear some forumer say can DIY it..
I 1 install at waja 4G18 engine 1....
the afr hv 3 wire 1..
hope u guy can help me..
erm EZ EZ... locate ur ECU.. den locate AIR FUEL WIRE... check diagram la.. den erm.. 3 wires ma.. 1 is to air fuel.. 1 is to 12V n 1 is to ground..
if u wan location.. u can try ask at southern motorsport at carrefour subang.. install there i think cheap ..
[snapback]860719[/snapback]​
i ask in southern lohhh,he cost me RM80
har? how come? i install apexi pen TT.. cost 20 buck oni lehh..
like dat u DIY lah.. take out ur ECU diagram.. locate the air fuel wire.. n den u tap 12V n another wire ground it at any metal place in ur car la..
mayb he saw ur AUTOMETER air fuel.. so wana chop u.. eheheh..try askin ppl who got air fuel meter... u can PM drill.. he DIY-ed his..
[snapback]863861[/snapback]​
that shop suck lahhh,imy frien dgo fix turbo timer it cost rm30..
But he time is FATT but the guy say only hv normal function n volt..
but last time that timer work in wira is full function 1.....
when fix he only tap 4 wire only,soem more cut it ori socket(mahai)
then afetr fix,he saytimer cannot run....then i call soem body it say wanna tap wire to handbrake wire 1......but that guy say tak mungkin 1....then my friend say eh wanna go...pay he RM30 n go...damn suck that guy!!!!!!!!!!!!!!!!!!!!!!!
eheeh.. duno.. mine no prob.. everything very good for me....
so how ? u dIY or goin shop? very satisfying leh diy.. ehehe
:ph34r:
Normally Proton will used Bosch oxygen sensor for thier cars. I'm not sure about Waja, but Wira is using Bosch sensor.
For your case, locate where is your sensor location. Normally after your extractor/exhaust header.
Trace the wire (it should be inside the cable loom, open a bit and you can see 3 wires. White, Black and Grey. If you see different color then the sensor is not Bosch. For this case better send to the professional).
Black color is the signal wire and you need to tee off the signal to your AFR meter signal wire (normally white color). For the power (normally red wire), just get from any 12V (better used non-critical, i.e. lighter and get from the fuse box). For the grounding (normally black wire), just connect to any good chassis/body ground.
If not confident I advice better don't DiY.
Go to this website for Oxygen sensor wiring color.
http://www.boschusa.com/AutoParts/TechnicalResourceLibrary/
Write your reply...
