Menu
Home
Forums
Current Activity
New posts
Search forums
What's new
New posts
Latest activity
News & Features
The Marketplace
Cars for Sale
ICE - In Car Entertainment
Car Shops and Services
Toys and Wares
All Other Stuff
Jobs and Vacancies
Looking For
Members
Log in
Register
What's new
Search titles only
By:
Current Activity
New posts
Search forums
Menu
Log in
Register
Reply to thread
Current Activity
Home
Forums
Car Brands
Car Manufacturers
Proton
how 2 mod gti?
You should upgrade or use an
alternative browser
Message
<blockquote data-quote="gtishadowfax" data-source="post: 1719958" data-attributes="member: 20219"><p>so many difference la...</p><p></p><p>1st, the color, of course...satria GTi - silver, satria R3 - black</p><p></p><p>exterior - standard GTi c/w JRD rims...standard R3 c/w Advanti rims...R3 using carbon fibre rear spoiler, GTi PU..., front bumper GTi got 2 fog lights, none on R3</p><p></p><p>interior - steering, GTi got airbag, 4 spoke, R3 using Momo w/out airbag, GTi aluminium gear knob, R3 carbon fibre, seat R3 using Recaro SR3, black with red linings, GTi using Recaro, black and grey, lightweight carpet for SR3, GTi non slip carpet biasa, with GTi emblem embossed on it, seatbelt R3 red in color, GTi normal black...</p><p></p><p>2 batches of GTi - the first batch was launched in 1999, 4G93 engine w MMC ECU. 2001 and above are using the same engine but w Siemens ECU..</p><p></p><p>satria R3 using the same engine w Siemens ECU, carbon fibre cylinder head cover with LEV code number on it. each vehicle comes with different code number as identification.</p><p></p><p>different suspension setting - GTi was tuned by Lotus, SR3 was done by our guys here in R3 workshop. A few more welding point was add up to standard GTi chassis, to make it stiffer for R3 version...</p><p></p><p>different exhaust system - donno how to explain this, but GTi got twin tailpipes, R3 one only...the extractor oso different.</p><p></p><p>braking system - solid discs all round for GTi, R3 with cross-drilled discs paired w high performance mintex brake pads..</p><p></p><p>pedals - GTi using aluminium pedals w GTi emblem on it, R3 also aluminium, but kosong one...</p><p></p><p>engine, piston sizs, conrod, air intake, air filter should be the same...but R3 has the upgraded performance parts, i.e extractor, high cams etc ready to bolt on - plug and play...</p><p></p><p>soundproof/insulation was removed from R3 - a part from its lightening process...</p><p></p><p>in other words, R3 is the stiffer and noisier version of GTi...which u can take on straight to the track from the showroom...</p><p></p><p>whateva silap/kurang, hope u guys cud add on...</p><p></p><p>sekian. terima kasih.</p></blockquote><p></p>
[QUOTE="gtishadowfax, post: 1719958, member: 20219"] so many difference la... 1st, the color, of course...satria GTi - silver, satria R3 - black exterior - standard GTi c/w JRD rims...standard R3 c/w Advanti rims...R3 using carbon fibre rear spoiler, GTi PU..., front bumper GTi got 2 fog lights, none on R3 interior - steering, GTi got airbag, 4 spoke, R3 using Momo w/out airbag, GTi aluminium gear knob, R3 carbon fibre, seat R3 using Recaro SR3, black with red linings, GTi using Recaro, black and grey, lightweight carpet for SR3, GTi non slip carpet biasa, with GTi emblem embossed on it, seatbelt R3 red in color, GTi normal black... 2 batches of GTi - the first batch was launched in 1999, 4G93 engine w MMC ECU. 2001 and above are using the same engine but w Siemens ECU.. satria R3 using the same engine w Siemens ECU, carbon fibre cylinder head cover with LEV code number on it. each vehicle comes with different code number as identification. different suspension setting - GTi was tuned by Lotus, SR3 was done by our guys here in R3 workshop. A few more welding point was add up to standard GTi chassis, to make it stiffer for R3 version... different exhaust system - donno how to explain this, but GTi got twin tailpipes, R3 one only...the extractor oso different. braking system - solid discs all round for GTi, R3 with cross-drilled discs paired w high performance mintex brake pads.. pedals - GTi using aluminium pedals w GTi emblem on it, R3 also aluminium, but kosong one... engine, piston sizs, conrod, air intake, air filter should be the same...but R3 has the upgraded performance parts, i.e extractor, high cams etc ready to bolt on - plug and play... soundproof/insulation was removed from R3 - a part from its lightening process... in other words, R3 is the stiffer and noisier version of GTi...which u can take on straight to the track from the showroom... whateva silap/kurang, hope u guys cud add on... sekian. terima kasih. [/QUOTE]
Insert quotes…
Verification
Post reply
The Marketplace Latest
~panel beating ~touch up paint ~polish/wax
Started by
jeff6126
BMW E90 M4 Mperformance front skirt lip
Started by
jeff6126
Honda Civic FC TypeR Bodykit/spoiler
Started by
jeff6126
Toyota hiace re-spray whole body
Started by
jeff6126
Proton Preve R3 body kit
Started by
jeff6126
BMW F30 M3 front skirt lip
Started by
jeff6126
Mercedes Benz W205 C-class GT grille
Started by
jeff6126
Nissan Almera Nismo body kit/spoiler
Started by
jeff6126
original rare TWS Southern Ways S05 15x5.5jj offset...
Started by
david tao
Honda City 2014~19year Drive68 body kit
Started by
jeff6126
Dynojet can't clearly read my car RPM...
Hopefully i'm on the right place to post and any sifu here can help me out. Just install bigger cc injectors into my car and is ready for dyno tune but problem comes out.... Its sounds weird, the dynojet can't 100%...
1992 MR2 front tyre size ?
hi all, can 225/40/17 install at the front of MR2 year 1992 (car lowered) ? any rubbing issue ?
because using 4 pcs same size tyre is easier for rotating....
what is the max size for in front ?
thx.
sign online petition for privacy glass
got this from wishclubmalaysia....... they are signing a petition online for the privacy & tinted glass issue...
Recent Posts
JB GERMANOIL - GROUP BUYS
Started by
HamburgLube
Mitsubishi
JB Germanoil for Lexus - Group Buys
Started by
HamburgLube
The Altezza / IS200 / IS300 Forum
Need advice on brakes
Started by
Crashout_Racer
Car Modification
Been stalking for 3 years edy
Started by
dheepadarshan95
Introduction and Newbies
Performance Tire Prices(Pls Contribute The Price & Location to buy)
Started by
JINEIL2EN
Car Modification
Log-in
for an ad-less experience
Home
Forums
Car Brands
Car Manufacturers
Proton
how 2 mod gti?
