Highest hp on 4g93 sohc Na
last time drive a 4G93P Sohc...dint dyno coz dont really know what dyno is last time...
now using 4G93P DOHC,auto...if i got time ill dyno it...btw, how much prize to dyno?
can use sohc ecu with dohc wiring? i thought the wiring differ between sohc n dohc... sohc using distributor, dohc r distributor less izzit right?
yeah its different...so im using 4G91 distributor + wiring...my car is rojak one...
wah.. i try to do that last time, but cant be done got money prob at that time.. huhu
so ur car feel better at higher rpm compare b4? now i still stuck with sohc engine...
the pick up of my car is very good...can get the feel around 2000rpm...its because my car has high compression...But top speed dont know can get 180km/h or not...i get 165km/h at 4000rpm...maybe can achieve 180km/h...dun dare to speed...
i think its better u use sohc la bro...or if want to swap engine,better go for mivec...4G93P twin cam engine is hard to find...
137psi @ 17.04kg-m , but DOHC , everything stock except extractor , piping and open pod and piggyback , bro can see the graph aer ?
my record for top speed is 210km/h at 6.5k rpm edi at 5th gear.. 0-100 around 8.6s like that la
using 1.5 gbx cable clutch oni, this is my third gbx as previous alwz kong doing harsh in changing gear like play daytona.. hehe
engine totally stock only with 2' piping with standard muffler.. last time using e-manage but recently take it out due to money crisis..
my old 4g93 DOHC..124hp and 164NM of torque last time...then the engine blew months ago...miss that set-up~:bawling:
that set up i made for full 300m race only..very2 FAST response...killed a SEG with 3sgte and a putra with stock VR-4 engine..but at that time..my car was strip to d max..hehehehehe:smokin:
Not that fast la bro..the engine is very2 realible..it lasted 2 1/2 years until one day...it sapose to do a routine oil change (due 500km) n one morning i was late to work..didnt heat the engine properly......few metres away...kaboom!!!....sad...but true...
Bump: Not that fast la bro..the engine is very2 realible..it lasted 2 1/2 years until one day...it sapose to do a routine oil change (due 500km) n one morning i was late to work..didnt heat the engine properly......few metres away...kaboom!!!....sad...but true...
sayang..actually u can still rebuilt ur engine..but there always pro n cons man..:smokin:
my customer wira aeroback from shah alam , 4G93 SOHC 128.4 hp n 118 ftlb on millenium dyno dynamic.
GOT any dyno sheets? very2 interesting..what is the specs??
sure got bro , but cannot upload yet coz my laptop problem. maybe next time coz too busy with this week drag event and 2 event next week.
spec are stage 3 block , port n polish head with stock cam , my spec ecu upgrade rev-cut , e-manage , 60mm t.body + stock intake , aftermarket extractor ..............:listen:
Ermm..what do u mean by stage 3 block??:confused:...With STOCK CAMS???!!! u get 128 on wheel?!! Thats very2 high for a single cam 1.8...Now its very2 interesting!...Cuz my frem...single cam
Spec..
1.8 block, high cam matspeed, campulley, GSR intake with 60mm throttle, emanage, bigger air flow sensor, uprated clutch (Red exedy cover, Malaysia spec), Ported n polished head, cusco exractor...dyno tune..gets roughly...127hp@ wheel...Please upload ur dyno sheet..its very2 interesting to see ur spec n engine...:driver:
hi all,
can anyone share how much whp should I get with below specs:
1.8 DOHC 4g93 NA
- with 1.6 4g92 high comp pistons
- port and polished head
- adjustable cam pulleys
- emanage
- acl race series race bearings
- ecu MMC 5537
- exhaust inlet size, front to back, 1.8 inches
- STOCK Muffler
hi all,
1.8 DOHC 4g93 NA
- emanage
- ecu MMC 5537
- STOCK Muffler
Just an estimation - gonna try my luck with knowledge.
- with 1.6 4g92 high comp pistons - High comp depends if its a full ratio or partial,4HP - 8HP
- port and polished head - roughly 10HP?
- adjustable cam pulleys - advance or retard?
- emanage - depending on the tuning.
- acl race series race bearings - this not sure add hp or not.
- ecu MMC 5537
- exhaust inlet size, front to back, 1.8 inches - Perfect size already. this one should probably add on 2-5 Hp at most.
- STOCK Muffler
so...Your stock:
Maximum Output - 103 kW (140 PS; 138 bhp) @ 6,500 rpm
Maximum Torque - 167 N·m (123 ft·lbf) @ 5500 rpm - Wiki
Now maybe around +23HP at most?
Just my bet on it though...May not be accurate.
Dyno maybe?
- ecu MMC 5537
- STOCK Muffler
so...Your stock:
Dyno maybe?
hello Ryuuken,
appreciate you reply.
sadly, I only got 123.60 wheel horse power after dyno
still wondering where the problem is at..any idea is welcome
