wait, your details here not enough, wether it can run on electricity or whatever, what is the criteria?? need to be natural source?? can it use solar panels? bla bla bla, all this must give abit info also mar, then maybe i can crack my head try to help you lorr.... ;)
btw, the copper and timah in lemon can make electricity charge, but a mere few volt and watts oni, can even feel it also, butthen can be read with volt meter lar :P ahahhaa, so lil, i think push tamiya motor also no power :lol:
alternatively, search for the source of how the car battery work, use the same materials and put it into smaller container(DIY-style) so your lecturer will think you did it yourself and not just direct buy the car battery and use it to power up your system lorr..
i believe the car battery, which uses H2O(distilled) to act as the "(damn, i forgot that term they use, erm, the one to make the charges more keng wan, pembati or something)" to make the reaction between the plates (i forgot what name adi) to create electricity which can be enough to power until the the charges run out lorr....(hint: the plates consist of 2 types of metal, the more the plate, the higher the charges and this produces gas and its kinda poisonous, so careful lorr)
sorry lar, alot things i cannot remmeber very well but i know i did study chemistry lastime and did some experiments with those plates which they were using to make car batteries, can me constructed in a smaller scale which wold produce enough power to power up your tamiya motor ;)
tips: try using the lowest and lesss resistance(in terms of spinning the coil/moving the rotor) motor they have for the tamiya wan, how to see wether the motor takes up less energy, the wires are thin and not too thick, the power of the motor wont be much but im sure with the amount of energy you ar feeding it, it could be the longest running motor/vehicle(with enough torque to push the small vehecle) around ;) and also use less stronger magnets in the motor to ease the movement of the rotor, too strong and you reqiure more energy to move the rotor coils...
