Help!! Ek3 swap manual GearBox
Mi is for Non Injection Multimatic...like mine is carb vers..how much u wanna sell ur Gbox..
SAO 6418,
where is the auto control unit actually??
SAO 6418 said:
Ok, i'm back.
I've check back my wiring again and the wiring tat disconnected from previous AT setup is the whole wiring tat attach to the CVT b/box coz manual dun need these wiring and just leave it there after disconnet it. Secondly come to the ECU. Our AT D15B come with two ecu, one is the main ecu and another one is the auto control unit. My main ecu No. is 37820-P2J-J62 947-138643 and the auto control unit is 28100-P2J-023, so unplug the socket for the AT Control Unit which suppose to have 2 sockets then the unit can throw away lah.
3rd is the socket from the engine bay which also suppose to have 2 sockets tat are not connected. These 2 sockets also wrap in the same wire with oil sensor or water temp. (not sure) which attach to the engine block.
apexivafc04,
i oledi connected the other two sensor v the orevious socket de. but there r no difference after i test drive it!!!
so, ??
I've oledi got d photos but exceeding the limits, so have to reduce it. onli the engine bay, the ecu there i did't manage to get coz i've oledi pasang the time took d pic, sumore d camera i pinjam onli.
I dunno d exactly loc of d at control unit, size half of the main ecu with AT Control Unit on it. U'll be able to see, if not most probably ur formen throw away lah since u r using manual mah.
https://www.zerotohundred.com/forums/attachments/73551
https://www.zerotohundred.com/forums/attachments/73552
i guess photos would quite small.
