why not u DIY yourself? just use a philips screw driver to adjust the screw behind the head lamp....
i used to do it myself at night....
u'll found 2 screw behind the lamp, 1 at the top and 1 at the bottom
turn it clockwise or counter clockwise..
Top : adjust Hi-low
bottom : left-right
find a place which your car is on flat level, and park it behind a car about 3 to 4 feet. then, adjust your beam right to the bumper on that car infront, slightly upper also can but not too much. if over that, your beam will be shining others on coming road user.
about left-right, try to make them shoot at the corner of the bumper infront..
after adjust, take a spin around your area, look on your adjustment, if not satisfied then come back and re-adjust again....
if can, ask your fren drive infront of u see if your headlight will blind him or not :D
if not, then your's should be ok liao~ :)
and the labour charge is RM 0.00.. hehe
cheers,
