~~Handbrake problem~~
najibkl
My meter handbrake sign does not appear when i pull off handbrake...Whats da problem?? Never happen before...
open up the console at the handbrake. You would see a switch on the handbrake mechanism. Check the switch to see if functioning properly. I think either the wire came loose or oxidation hence no proper connection.
trex92 said is true. but if problem persists, check bulb. he he
Thx gang...Appreciate it...Got switch huh??
switch looks similar to door ajar switch. normally spring actuated.
