good manual gearbox oil
abunawas
80
43
518
anyone can recommend a good brand and performance gearbox oil for a normal 4G15 engine gearbox ? car is just a Wira.
i scared put wrong oil and gearbox rosak
some told me to look for toyota and honda gearbox oil....where to buy?
khoyos
2,632
156
5,163
Shah Alam
toyota gear oil is good enough. but if u want something even better, torco RGO & redline MT90 are my favourites. price RM60 per liter. depends on how u drive ur car
I had the redline gearoil in my car. MT-90
If I recall, it was RM65 a bottle 1L. I only needed 2L to fill it.
If you DIY do this it's quite easy.
---------- Post added at 02:38 PM ---------- 6 hour anti-bump limit - Previous post was at 02:36 PM ----------
Oh, and stick with GL4 oil. 75W90 is more than enough too.
mADmAN
1,840
547
3,213
the toyota and Honda MTF-III oils are pretty good oils... just go ahead with them.... can get in spare parts shop
the Honda oil is about RM180-200 for 4L depending on where u buy... the toyota cant remember... cheaper iinm
truth be told... even the tong drum cheapo gearbox oil is pretty decent...it does the job.. i even used it in my old VTEC gearbox with LSD and i used to have quite alot of drags with that car... and also a number of track days.
abunawas
80
43
518
the toyota is this one?
or
or
always confused between manual transmission oil and gear oil
---------- Post added at 02:52 PM ---------- 6 hour anti-bump limit - Previous post was at 02:50 PM ----------
i have seen those toyota ones sold in shops, anyone knows where to buy the Honda MTF 3?
Dude, look carefully. It says GL-5 there in the silver can. That might not work well with your 4G15. Stick with GL4!!
anyone knows about this?
I use before, can get from spare part shop. Roughly RM20 per liter those days. Viscosity is 75w-90.
Now just use normal Castrol 80w-90, very cheap only. This is in my VR4 GB.
Your 4G15 no need those expensive FS MTF....:driver:
castrol 1 liter how much?
Went and check my old bills, found Castrol was quite long ago, lately my mechanic use Mobil MTF in my ride. RM16 per liter. Cheaper because he pump from his 20L tub....:driver:
Zeroshift
133
13
16 per liter? That's cheap...Any idea what's the oil specs?
The Marketplace Top Posts
Subaru Technica International has released the STi package for the 2 models above. The "Tuned by STI" cars are based on the <b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b>2.0 GT spec.B package, which nestles a 260-hp/253 lb-ft (5AT) or 280-hp/253 lb-ft (6MT) turbo four-cylinder underhood. From...
