Getz or Accent RX-5S???
AJ6677
587
Melawati
Need help from u guys here. whc one is better? the getz 1.3 or the accent RX-5S (hatchback)? ur comments and views is much appreciated. thanx...
AJ6677
587
Melawati
kingkong bro...
actually my gf is buying the car. the reason is the 2 cars are within her budget. test drove the 1.3 Getz last week and its quite ok just that im afraid its a bit underpowered. havent got the chance to test drive the Accent as yet. dunno whc is better in terms of handling and overall performance. not looking at the 1.6 Getz.
kingkong
47
PJ
www.myaccentclub.com
Okay..
You will need to do some research on both cars
For Accent RX-5S go http://www.myaccentclub.com/forum/index.phphttp://www.MyAccentClub.com
For Getz 1.3 go http://www.getzclub.com.my/forum/
I am currently drive an Accent and have also driven my friends Getz. So far both cars are value for money.
Alarms:
Getz standard car is keyless entry.. that means it can only open door remotely (no alarm system). Accent RX-5S comes with alarm and keyless entry..
Will write more when I think of more things to compare... :regular_smile:
AJ6677
587
Melawati
thanx bro...wld appreciate it so much if u can help me. got no time to really survey these 2 cars. thanx again...
Hi guys, i hope to get some opinion before i get chopped few thousands..
If this bad smells happens on your car, which one would you do first:
A: It came out from the exhaust, there might be a leak or something clogged, i should go to exhaust shop.
B: I should go for repair workshop for a TB and intake manifold cleaning. Cause the smells is similar with a WD4D burning, and few years ago there's really a mech did a WD4D clean into my TB without taking the TB out.
C: Try diy change...
