fuel consumption for sw20
razmrtwo
50
12
Mine does 4.7km/l with heavy right foot. If driven gently, I think it can do 7km/l
EDDYSW20
114
20
Negeri Sembilan
I always fill it up full..... from empty and it does take around 45-47 liters. I do not wait for the tank to run total dry (54 liters)...... anyway, RM90-RM95 of RON97 for 400kms standard for the past few months. Its a little better with V-power, but the petrol price defeats the fuel saved..... and I run a 245 powerplant..... my 2EFE and 4EFTE was way waaaayyyyyy better...... but less a 100hp and 700cc laaaa.... heheheh
And yes, I am the guy with the tons of spare parts, selling dirt cheap and still everyones interested in getting new stuff, or expensive stuff from the net, you rich fellas!! hahahaha....
And if you need some technical advice, I may be of assistance since I've practically dismantled and reassembled the whole car a few times..... front, back, inside, up and down...... soon to be dismantled again to be sent to the paint shop!!
Cheers guys.....
---------- Post added at 05:21 PM ---------- 6 hour anti-bump limit - Previous post was at 05:18 PM ----------
Sorry, I meant 2E-TELU.... always get that wrong!! Incase you're wondering it's a starlet.... love that small machine!
EDDYSW20
114
20
Negeri Sembilan
5 refuels ago.... for a consecutive 2 refueling found that the car only did 350kms..... that was not good. Started looking here and there but noted the battery was weak, and headlights pretty dim...... so, replaced the battery about 3 refuels ago, and the fuel consumption has decreased back to its 400kms per refuel.... and that came with better headlights beam, better performance, and better power..... just a freakin battery change!!!
alvin24
3,113
27
whoa... serious shit... my car only does 300+km on full tank... and it's an n/a... -__-"
something must not be right... sigh
EDDYSW20
114
20
Negeri Sembilan
Serious man..... anyway, for your analytic purposes..... this is the summary....
Year 2010 :
Fuel pumped in 1634 Liters, Distance travelled 13663 Kms, consumption comes to an average of 11.96 liters/100kms or 8.36 kms/liter with the best record being 10.57 L/Km and the worst being 13.32 L/km. The worst was recorded during the battery issue!
This has to take into consideration the fact that I run on 235/45ZR17 at the rear, which makes the odo a little inacurate. 150km/h speedo is 160km/h GPS, and other odos read 165km/h. Its that far off!!
Alvin, you could be pushin your N/A a little too much, if thats the case, then you're better off with the turbo charged engine. I usually drive from 20km/h to 100km/h in 8 seconds or so...... good consumption, but still ahead of traffic, way ahead. why not from 0? Cause waste petrol and burn rubber..... especially after my silap spinout on first gear, I only accel on second now.... kinda laaa..... hehehehe.....
alvin24
3,113
27
lolz... yeah, I'm still trying to figure out what's with my FC. -__-"
It could be that I take a lot of small roads to work... practically half my journey to work is on 3rd gear (takes me 20km to go to work... so 10km on 3rd gear). On the other hand, my Myvi doesn't suffer from bad FC when I use the same way to work...
Anyway, ultimately the plan is to shove in a turbo... but learning to drive the car while it's still n/a... so transplant I only foresee it happening in 2012 lah... not that soon. Wanna also see how far can this n/a go... where does it stand when on track with other 2-litre n/a
EDDYSW20
114
20
Negeri Sembilan
Hemmmm, somehow I do not think you'll be prepared for the turbo, using your N/A..... its just different.... you venture into new terrain with the turbo installed...... like, drifting on a straight road! drifting after a turn! tyre spin out after a little more throttle on first gear! And bet you'll be shocked how quick you finish up those rpms..... rpm cuts.... and start hunting around for the next gear! Hahahaha.... kena a few times when first bought la..... tarak biasa rpm reach 7+k in 2+ secs..... on first gear la..... hahahahah..... and my favorite..... throttling to make turns at the roundabout..... d amn nice...... definetely can't do it on N/A..... friends interested in the car tarak berani test drive after I brought them thorugh a roundabout and showed them the capability for the car changes steer angle using only throttle input, steering maintain, otak standby for disaster..... lolz..... :evil:
alvin24
3,113
27
LoLz... well, it's not that i'm inexperienced... had been playing cars for the past 8 years or so, and I sold off my 350hp Satria evo to be replaced by the MR2. I understand well how a turbo performs. What I wanted, was a change of platform... so the MR2 it is.
There's 2 main reasons why I gotten myself an n/a MR2 to start off with.
Reason 1:
So that I can concentrate on learning how to handle the car better, because n/a powerband is much more linear than stock turbos (due to many critics say MR2 is hard to handle - better safe than sorry mah). It's easier to estimate the throttle power, thus easier to learn how the car behaves under various situations, and learning the car's limits. With past turbo engine experiences, different engine+turbo+tuning setup will have the car behave differently. Even my evo with and without the highcams behaved totally different. So I didn't want to have too many factors in my equations on learning how to drive it.
*not sure if that makes sense to you guys... not sure how else to explain that... haha*
Reason 2:
Cheaper to buy an n/a and transplant than to buy a turbo. Turbo halfcuts + LSD i asked were going around for 5k++. Transplant fees roughly about 1.2-1.5k if no dashboard rewiring required, of course not including hidden costs.
I see most people selling turbos for 55k plus minus... where as N/A goes below 40k.
That is the logic I've come up with lar. I don't expect to be able to 'master' the car's handling anywhere under 1 year. U all sifu have been driving the car for ages will have to teach me! =)
I got join GRA a couple rounds before with my satria evo... but my category winners are all 4WD and RWD... somehow the FF feels a bit lacking... further more satria + evo engine handles like CRAP... front too heavy, understeers A LOT. Must slowly plan my REVENGE in the MR2! haha
edit:
Just realized I'm kaukau off topic. LoLz...
To add, my Satria mixed driving also can get 330km per 40 liters petrol.
My close to stock MR2 n/a seems to be doing the same kind of mileage... -__-"
It's quite frustrating since I'm having less than HALF the power of my satria now with equal mileage -__-"
EDDYSW20
114
20
Negeri Sembilan
Wahahaha...... superb!! A 350Hp Satrialution!! Straight line must have been dramatic, and corners must have been scary.... I agree the satrialution is too light a car, the wiralution is much better...... bet you the inspiralution would be great though!!!
So, now I understand your reasoning, and kind of figured out your crappy FC. A RWD usually consumes much more than a FWD, thats what I've noticed. Could be different per manufacturers spec. And if you're used to a 350 horse car, I cannot even comprehend how you drive in a MYvi..... must be kinda sad...... hahaha..... just kidding bro!
Anyway, good you think an MR2 will be able to revenge..... hehehe, I'm glad..... a little proud too.... huahahah..... so, how long you've been 'training'? From understeer to oversteer..... i like more oversteer..... used to go off road with my satria, many many years ago...... loved it, but still think MR2 a better trade..... can do oversteer on the dry road!! Satria can only do understeer on dry road.... huhuhuhu....
Kudos Alvin, all the best in your 'training' and FC regulation....
alvin24
3,113
27
Yea, Satrialution handling quite teruk... wira would definitely be better... i think with the evo engine my satria weight distribution is probably something like 80% on front tires. LoLz... got LSD helps a lot when I floor my way out of the apex... but I'd imagine on a wira it would be more awesome. =p
hAHAHa... My satria I just sold off not long ago to get the MR2, the Myvi was with me 2 years plus already. Myvi is my everyday car ma... satria/mr2 is more for weekend use. LoLz... believe it or not, I've had the myvi for 2 years++ now and I've never revved it past 4k rpm before. LoLz... I quite slow driver on the roads wan... on tracks is a whole different alvin24 unleashed. LOLz... Myvi fuel consumption is quite excellent lah... pump 50-55 bux of 95 ron can go past 400km. If drive outstation I went past 600km before.
I think it's going to take a while before I reach the stage of getting my revenge. HAHAHA... GRA somehow I feel favors 4WDs more than RWDs. Need you guys to teach me how to handle the MR2 better... right now, I'm still quite the noob. lolz...
Btw, Eddy you're from Nilai right? Which part? Any open spaces to practice ar? Maybe I come over cari u yumcha one day... lolz. You seem to own a workshop or something, got so many parts for sale wan!
EDDYSW20
114
20
Negeri Sembilan
I recently shifted to Nilai. Sorry la, no workshop. My garage is my workshop! Open space for training? I recommend you try out the parking lot at shah alam stadium. Have seen a few cars burn rubber there before.
Actually like some SW20 owners have claimed, they don't really drive their cars daily, many use the car on weekends, so, if you're really interested to know your car, you need to drive it daily, I think thats the best way to learn la...... and thats exactly what I do, also because the MR2 is tons of fun to drive la....
alvin24
3,113
27
LoLz... my MR2 is semi-daily la... I drive it to work everyday when my sister is back in KL, I leave my myvi for her to drive.
If my sis is not... then I drive it to work every few days or so. Weekends depend on where I go and whether or not I need to fetch ppl. =p
Anyway... it's way off topic di. Hahaha... IF i free and nothing better to do, might just go down Nilai look for u yumcha... will PM u if I do la. =)
EDDYSW20
114
20
Negeri Sembilan
Roger that!!
Semi-daily driving, there's also the possibility of your vehicle losing fuel through the vent line, fuel cap and piping. lost up to 50kms of fuel when then fuel cap failed. Easy test - make sure strong vapor exits the refuel pipe when you open the fuel cap, bunyik sshhoooosssshhh..... if not, that means your fuel cap could be releasing vapor, or you've got a leaking line, tank, cap.......
Back to the topic eh? hehehehe
alvin24
3,113
27
Hmmm... good point, never thought of that... come to think of it I don't think I heard the 'ssshhooooshh' sound we're all familiar with coming from the MR2... will double check later, coz' my tank almost empty again on my way home from work.
alvin24
3,113
27
OK i pumped petrol last night (before price increase! haha), and that's not it.
I open the fuel cap that time got the 'sshhhooooooosshhh' sound.
oblivion
86
24
Hi Guys,
I'm just wondering how many of you is using ROM 95? So far, i'm only using RON 97.
Thanks.
alvin24
3,113
27
3S-GE.
I'm also on RON97
xMika
623
85
Selangor
Weird .. my 3S-FE also got the same fuel consumption as you .. 45~48 litres can go 300km only ..
mrtwo
84
17
508
well as for me, ron 97 3sgte, 50 ringgit can go from puchong -seremban-puchong-ttdi-puchong-kota damansara-puchong.dun know if thats economical or not..didnt push hard tho..
Guys,
need your opinion on RCS vs titan. I know that both of the product are custom made absorber.need your comment on quality and ride experience. I have use titan before and yet to know how is RCS compare to it. Planning to put into my ride in near future.
rgds
