FS: Orion XTR900.2 & DLS UR12 sub
ICE -In Car Entertainment
akdoV
XTR900.2 used less than 3 month la..... the sub may b 1yr++....
open forsale till 24 April 2006 ( Monday ) after tat will b not 4sell ler.... so hurry up.... Price?? sms me at 012-3033319 thanks ;) good price good price.... !!!
http://img.photobucket.com/albums/v338/vodka76/108F63941420.jpg
http://img.photobucket.com/albums/v338/vodka76/108F63940500.jpg
http://img.photobucket.com/albums/v338/vodka76/UR12_front_F.jpg
http://img.photobucket.com/albums/v338/vodka76/UR12_rear_F.jpg
nice amp le wei hahahaaaha how much u selling le dellllllllllllllll let me know la if cheap then i buy la
wah...this is already so highend stuff, I wonder what are you up grading to..
Maybe "Yat Sun chung yau Yat Sun ko" :)
BTW, not that I can afford it but worth a try, can PM me the price for the sub?
thanks bro,
Built on a reputation of quality and reliability, the XTREME amplifiers embodythe true meaning of power and performance. Delivering massive power from ORION'sexclusive PRS power supply, there isn't a stronger amplifier on the market.Their complimentary Bl-polar output stage, commonly found in audiophile homeamplifiers, offers superior clarity and transparency that is impossible withcommon amplifier designs. For system flexibility the XTREME series of amplifiersoffer a fully adjustable crossover, dual gains and ORION's proprietary subwoofermaximizing circuit, INTELLiQ. Engineered for those who aren't willing to acceptcompromise and take it to the XTREME.Product Features: Separate left/right gain controls Separate left/right phase controls Variable high pass, low pass, or bandpass crossover INTELLi Q bass optimization circuit Remote gain capability 4 gauge power/ground 12 gauge speaker PRS power supply Complimentary matched Bi-polar outputs Traditional ORION fly-cut graphic 100% QC Tested 2 Ch x 225 Watts @ 4 Ohms 2 Ch x 450 Watts @ 2 Ohms 1 Ch x 900 Watts @ 4 Ohms Variable Low-pass 45Hz-5kHz Variable Hi-pass with INTELLiQ 10Hz-10kHz 10 dB of boost with INTELLiQ Remote gain capable Selectable AUX out Fuse Size: (2)30 ATC Dimensions: 18" x 10.25" x 2.25"
DLS UR12
Speaker type : Subwoofer
Impedance : 2 x 4 ohm
Size : 12" (30 cm)
Power handling capacity : 500 W RMS / 800 W max
Frequency range : 20-2000 Hz
Sensitivity : 87,2 dB (1W/1m)
Magnet size : 220 mm (8,7"), 200 oz
Outer diameter : 310 mm (12,22")
Installation depth : 150 mm ( 5,9")
Mounting hole : 282 mm (11,1")
Weight : 13 kg (28,66 lb)
X-max : +- 14 mm (0,55")
Fs: 36,1 Hz Re: 1,85 Qes: 0,32 Qms: 4,98 Qts: 0,3 BL: 16,1 Vas: 24 l (0,85 cuft)
let start a bid , so far high offer RM1.2K for the Orion XTR 900.2,DLS UR12 Sub RM800 ...... come come!!! bid end on 24 april 2006 Monday Time:1800
update !!!
update !!!
Orion XTR900.2 as good as Alpine V12 MRV1505 or 1507.... bump for you... heard you eyes on this 2 stuff.....Diamond Audio D912 D2 Subwoofer & Diamond Audio D6 1500.1 Monoblock ... haa haa good luck... My brother interested on the Amp but .. he not here loorr... at Batam right know... unlucky loorr.....
