FOR SALE: GREDDY E-MANAGE (Engine Control Unit Manager) - Special Offer RM9xx
Cola
Selangor
Item is brand new with 1 year warranty.
Contact: Larry 012-6527100
COD Location:
Shah alam/Subang
Courier Postage:
Within Malaysia (Tracking online) (Arrive on next working day)
What is an E-Manage? What can an E-Manage do? An E-Manage belongs to the category of electronics called piggyback controllers. They are called this because the do not completely replace the factory engine management unit, but rather work in conjunction with the factory unit to allow you to tune and control specific aspects of the engine's operation while allowing the the original to maintain control of the rest. It is the best of both worlds!
The GReddy eManage is one of the Least Complex Programmable Engine Computers. Instead of Creating a new engine harness for a stand alone system, the GReddy eManage is a piggy back computer that will intercept signals from the engine and allow you to make tuning corrections. The GReddy eManage can control numerous function and can take readings from GReddy Warning Gauges. The GReddy eManage will allow Tuners to Adjust for Fuel Injectors, Larger Turbos and Camshaft Changes through the E-01 Programmer or a Windows Based Laptop using The GReddy eManage Software. Installs in 1 Hour.
Features of the GReddy eManage Include:
Today's engine management unit is an incredibly complex piece of machinery. It does far more than simply control the delivery of fuel and ignition to the engine. They also control valve timing and are responsible for adjusting emissions. Nearly every piece of electronic equipment in the car ties its operation into the ECU. You can't simply yank it out and expect the car to operate correctly.
Fortunately, there is hope for the auto enthusiast who needs to extract more performance from his or her car than the stock ECU was intended to provide. That hope is the GReddy EManage. This precision controller will allow you to adjust a broad range of performance-related controls in concert with the ECU. The result? Killer performance and a car the works properly, as the manufacturer intended. Consider just a few of the things you can control with your GReddy EManage:
Fuel Delivery - Compensate for upgraded mass air flow meters, throttle bodies, or fuel injectors.
Adjustment of fuel delivery at 5 different RPM ranges
Adjustment of air flow meter signal by up to 20%
Incorporated Fuel- and Boost-Cut Controller
Control of up to two additional injectors activated by boost or RPM level (with optional boost sensor)
Idle adjustment circuit included
Air & Fuel Control
For Larger Mass Air Flow Meters or Throttle Bodies, you can adjust the Air Input Signal ±20% to Correspond with the Correct Proportional Amount of Fuel Delivery
Fuel Delivery can be Adjusted at 5 Different RPM Points for use with Larger Injectors
Auto Idle Correction to Prevent Engine Stalling
Fuel / Boost Cut Controller Included to Allow Maximum Horsepower from the Turbo and Prevent Lean Run at Top end RPMs. Optional Boost Sensor & Harness allows for More Refined Turbo Interaction & Control
eManage Can Control up to 2 Additional Injectors that can be activated by RPM or Boost Pressure (Optional Harness Required)
Ignition Timing Control
With the Optional Harness, you are able to control Ignition Timing for High Boost Conditions
Vtec Control
Adjustable Vtec Control for RPMs, Engine Speed, Hold Between Gear Shifting
Unlimited Vtec Adjustment
For Vehicles with Vtec Engine Swaps, The eManage Can be used to Activate V-TEC for a Non-Vtec ECU.
Unmatched Fuel Control, Richen or Lean ±10% out the Fuel Mixture when Vtec Engages
VTEC Timing - Have one of these in your car? Now you can do even more!
Set valve timing based on Engine Speed
Use your factory non-VTEC ECU with your VTEC engine swap!
Monitoring Functions
Data Logging and Display through E-01 or Windows Laptop
Map Tracing of Fuel, Air Flow, RPMs and Vtec Operation.
The eManage has password Lockout and Retains Memory of Settings if the Battery is Disconnected
sir, rm900 can ah? all is complete set kah? means all harness is include?
RM900 is not possible bro... this is the best price I can offer.
The complete box set does not include harness, software / cable.
Harness is RM180
Software / cable is RM150.
Support tools is software and cable rite. does it include manual too ?
sir, now e-manage blue rm1000 with ignition harness.. can nego...
Pls PM me price for basic harness and ignition harness. TQ!
hi cola, can e-manage remove speed cut n rev for type R ECU ?
