Item(s):focal dual monitor amplifier
Package includes: amplifier, 2 x manual, usb cable, remote control and cable remore control, 4 x 40 fuse
Price:RM3.5k(market price over 10k)
Warranty:1 month
Dealing method:cod
Location of seller:cheras
Contact method/details:0196888070 / 0125300509
Age of item:over year but never install in car
Item(s) conditions:10/10
Picture:[attachmentid=2509022]
[attachmentid=2509026]
[attachmentid=2509027]
[attachmentid=2509028]
Nominal power measured at 13.8V continuously @ 4 Ohm :
2 x 250W RMS
Nominal power measured at 13.8V continuously @ 2 Ohm :
2 x 400W RMS
Power in bridged mode measured at 13.8V continuously @ 4 Ohm :
1 x 800W RMS
Power in bridged mode measured at 13.8V continuously @ 2 Ohm :
1 x 1 200W RMS
Power supplies :
Dual fully regulated
Signal/noise ratio :
> 110dB (A)
Damping factor at 4 Ohm :
> 600
Frequency response :
10Hz - 40kHz
Input impedance :
13 kOhms
Input sensitivity :
0.2 - 5V
Digital input :
Coaxial/optic
Output stages :
Transistors:
6 Toshiba 2SC5200
6 Toshiba 2SA1943
Operational amplifiers :
Burr-Brown ®
DSP :
2 internal DSP - 180 MIPS each
Converters :
24-bit/96 kHz Crystal ®
Software :
Provided
Remote control :
Provided (gain + 5 presets)
Digital EQ (each input channel) :
30 bands of 1/3 octave
Digital delay line (each input channel) :
4 independent outputs, 22ms max.
Digital control :
From external PC via USB port
High-pass filter :
(with on/bypass switch) Slopes and frequencies fully adjustable
Low-pass filter :
Parametric EQ :
1 band fully adjustable
Maximum cross section of loudspeaker cables :
10mm2 - 7 AWG
Maximum cross section of power cables :
53 mm2 - 0 AWG
Protections :
- Short-circuit
- Continuous power
- Thermal overload
- Soft clipping
- Overvoltage
- Polarity reversal
Dimensions ( H x W x D) :
50 x 540 x 280mm (2 x 21.25 x 11")
Weight :
7.5kg (16.53Ibs)
Warranty:1 month
Dealing method:cod
2 x 250W RMS
2 x 400W RMS
1 x 800W RMS
1 x 1 200W RMS
Power supplies :
> 110dB (A)
> 600
10Hz - 40kHz
Input impedance :
13 kOhms
Input sensitivity :
0.2 - 5V
Digital input :
Coaxial/optic
Output stages :
Transistors:
6 Toshiba 2SC5200
6 Toshiba 2SA1943
Burr-Brown ®
DSP :
Converters :
Software :
Provided
Remote control :
Digital control :
High-pass filter :
Low-pass filter :
Parametric EQ :
10mm2 - 7 AWG
53 mm2 - 0 AWG
Protections :
- Short-circuit
- Continuous power
- Thermal overload
- Soft clipping
- Overvoltage
- Polarity reversal
Weight :
7.5kg (16.53Ibs)
