mind I ask u .....since when this happen ?? rite after u ON PFC or ON EVC ??? or u played with your EVC settings ??? maybe u could ask your tuner to set your u........jerking too much is not a nice riding experience oh ;)
i think i do not have boost cut. b4 this i use greedy boostcontroller also the same thing. b4 i go for power fc also the same thing. but after i change the plugs to denso iridium plug7 is better but after a week it came back already.
ic. last time i hv problem when boost over 1.2bar as once pass 1.2bar the car feel like choking and got misfiring issue.. tat's was due to spark plug problem. Problem solved after changing spark plug. You might want to check ur spark plug and coil.
For stock e7 turbo, it can stand SAFELY at 1.6bar maximum (guideline)(of course with proper tuning).. above 1.6bar the turbo will be very tired... so wear and tear for the turbine will be higher...
suspected tuning issue (might be the A/F ratio - too rich ) and cause the spark plug life span shorter.... Try to clean the spark plug (carbon deposited) then Tune cantik2 first.
hehehe......finally i get it done already........ the spark plug regap ok already now 1.8 boost also can no problem (testing onli) me running 1.5 safe safe mahhh
Pic 1 - Remove the original regulator with 2 screws, first remove the two hose that is connected to the regulator one with the clip and the other one is the vacuum hose.
Hi all,
I just bought r32 & plan to swap with the rb26dett. What I know the engine mounting re direct bolt on but have to look for the rb25det trans & axle. My quetion how to modify the rb26 oil pan? Any other parts...
