EK4 96 Digital Aircond Control
Thanx for the reply.
Hikaru said:
I'm not sure what kinda climate control you have in the first place but this particular one is the digital climate control. If yours is local EJ then you have to change the complete wiring harness from climate control to blower and cooling coil. The transistor on blower is different and you have to add an extra relay.
All JDM climate control has hot air option so the working mechanism is different. You gotta swap the center core as well so that you can lead the water from engine bay to create the hot air and hence adjust the temperature.
You will need more than just this climate control panel alone to make everything works.
yo bro,thanx for the reply, well as for the climate control that i'm having rite now is the same as what you are selling. i dont really understand the relay that you are refering too? actually i'm already change the fan control relay. if i'm not mistaken that the relay is for speed controler, and as for the wiring harness, well i did a complete swap... the only thing i didn't swap or change is the heating coil into the fan coil area. i think that is the problem rite? oh one more thing is that i didn't connect the heat valve controler... gosh... anyway. do you have any guide line or wiring harness diagram that i can refer too?? if it not that difficalt for u... thanx for your help bro. hope to hear from you. take care and have a nice day.:regular_smile:
