WalBro(Apexi) said:OEM OBD2 civic P2T ECU for B16a motor. ECU This is an unmodified, OEM ECU that has been pulled out of a working vehicle. Looking to tune your car for more power? OBD2 is not tunable and can not be chipped. Get a OBD1 ecu and a conversion harness
try get OBD-2 to OBD-1 hardness.run P30 ecu if u wan chip ur ecu.thanx!OBD2B to OBD1
hattech-v said:one more think, that skunk2 conversion harness only will cost u near 1K... + ecu + tuning almost 2K++... add a bit can get standalone i think.... hehe
hattech-v said:yes i do... hehe
Oderf said:we r running with the same basic engine then. 1 question, what's the actual spec for this B16A4 ? been looking for answer in the net for quiet somtime but no convincing one yet so far. hope you could help me out coz some said it's same as a B16A2 and B16A3 which is less power than the genuine JDM B16A SIR2 (EG6/EG9).... an some said it's the same... which one is correct ? tks
hattech-v said:i think it has the same power... even on the net quoted 170hp...
i've tested with one ek with b16a eg jdm... side by side all the way 400m but leading a bit.... hehehe..... top not sure...
WalBro(Apexi) said:woh.rm1k no need lar.i give u under rm700.if u interest.heheheh
i can get u cheaper hardness!tat is nop skunk 2 but work same.under rm500!intersest.i send pic to ur e-mail already check it out!
only the ecu not same... but still using P2# code which is same with JDM EK ecu code...
