FAQ
Q: What is an Electronic Cigarette?
Electronic Cigarette is an electronic smoking device or which is also known as E Cigarette or E-cig. It is a non –flammable product that uses state of the art classy micro-electronic technology which provides smokers a real "smoking" experience without the fire, flame, tobacco, tar, carbon monoxide, ash, stub or smell found in real cigarettes. It is a device to help people quit smoking or continue to smoke safely without danger. It looks feels, taste & satisfies almost like real cigarette
Q: What comes with the set?
1 Portable Charger Case (PCC), which holds 5 cartridges & charges your Ecig batteries on the go without cords when the PCC itself is fully charged.
2 Batteries
1 Atomiser
1 UK wall plug adapter
1 USB charger cord 1 that charges the PCC (You can charge using computer)
Q: How does it works?
SmokerHaven E-cigarette comprises three parts: Battery/Microcomputer, Atomiser (vapourising device) and Cartridge (It contains the Liquid solution). When you inhale through the mouthpiece a sensitive micro pressure switch activates the rechargeable battery and micro-electronics which immediately causes the vapour device to vaporise a tiny drop of the cartridge liquid. The vapour contains vaporised nicotine within the ‘mist’ which in turn is delivered straight to the blood stream via the lungs giving you that instant ‘smokers fix’ and a relief from cigarette craving.
Q: How to smoke?
Just smoke like real cigarette.. However it should be smoked at a much slower, deep & controlled rate.
Q: What are the contents if the cartridge?
It just contains water, food flavouring, Propylene glycol and nicotine. Fun Flavours does not contain nicotine
Q: Is nicotine dangerous?
Nicotine by itself is not dangerous. It is just like caffeine in Coffee. It is addictive but not dangerous. In fact Nicotine in cigarettes is not dangerous, the burning process and other 4000 chemicals is the one that is dangerous like tar, carbon monoxide, carcinogens etc
Q: What is Propylene Glycol?
Propylene glycol, an organic compound is like a moisturizing agent used in food & medicines like cakes, cookies, food colourings & flavourings. It is an odourless and colourless viscous liquid. It is also present in regular cigarettes being used to maintain a dampness in the tobacco. It is recognised as generally safe (GRAS) by Food and Drug Administrations throughout the world. Propylene glycol is the main ingredient present in the E-cig cartridge to provide the vapour that looks like smoke and to suspend the nicotine and flavour.
Q: How long does the cartridge last?
1 cartridge could provide 120 to 180 puffs. That’s approximately a pack of 14 to 20 cigarette sticks. Depends on how you smoke
Q: Can I quit smoking using the e-cig? How?
The E-cig is an effective smoking cessation device. It has helped a lot of people quit smoking the easy way. However efforts and will power are required as well. Reduce your nicotine intake gradually from high to low. Eventually quit smoking totally
Q:Can I save money smoking the e-cig?
The price of a pack of 20’s will increase over the years. Calculate the difference of 1 cartridge to 1 pack of cigarette. Multiply by the number packs you consume per month and you could get yourself a new car from the saving! i.e Dhill pack of 14's rm6.9o x 365 =RM2,518.80, eCiggy rm3.oo x 365 + 29o.oo = rm1,385.oo # 2518.8o - 1385.oo = SAVE rm1,133.8o
Q: What are flavours available?
Inspired by Dunhill (High & Low Nicotine)
Inspired by Marlboro (High & Low Nicotine)
Havana Classic Tobacco (High & Low Nicotine)
Minty Menthol (High, Low & No Nicotine)
Jave Coffee (High & No Nicotine)
Shisha Vanilla (No Nicotine)
Shisha Strawberry (No Nicotine)
Chocolate Indulgence (No Nicotine)
Orange Citrus (No Nicotine)
Q: Can I smoke the e-cig in NO Smoking places?
Yes you can and totally legally! It does not produce any smoke. Only WATER VAPOUR. You can even smoke your E-cig in the aircraft; it is not detectable by the smoke detectors. However to avoid lengthy arguments, when you are in the aircraft or cinema, just cover the glowing tip and enjoy smoking the E-cig
Q: Is it safe?
Most harmful products in a regular cigarette are produced as a result of the combustion/burning of the tobacco & paper etc. Eg: Carbon monoxide or any of the other 4800+ chemicals and carcinogens that tobacco smoke produces. SmokerHaven have no toxins or by-products produced by combustion. It shows no evidence of being a carcinogen (A carcinogen is any substance, radionuclide or radiation that is an agent directly involved in the exacerbation of cancer or in the increase of its propagation. This may be due to the ability to damage the genome or to the disruption of cellular metabolic processes. Several radioactive substances are considered carcinogens, but their carcinogenic activity is attributed to the radiation, for example gamma rays and alpha particles, which they emit. Common examples of carcinogens are inhaled asbestos, certain dioxins, and tobacco smoke.)
Q: Why safe?
Because it does not contain any dangerous chemicals,Tar, Carcinogens, Carbon Monoxide and other 4000 chemicals found in cigarette Q: ANY SIDE EFFECTS? There are no side effects at all. Everything is organic substance.
Q: What is the difference of SMOKERHAVEN from other model / brand?
Most other models/brand are of very poor quality. No warranty. No after sales service at all. The worst part is that most of these other brand/models contains Diethylene Glycol
Q: What is Diethylene Glycol?
Diethylene glycol is poisonous substitute for Propylene Glycol because it is much cheaper. It is used as anti freeze substance. So be careful when you buy other brand of Electronic cigarette
Q: Does SMOKERHAVEN e-cigs contain Diethylene Glycol ?
Absolutely not! Unlike most other model & products. SmokerHaven Electronic Cigarette does NOT contain Diethylene glycol. This is confirmed by lab report from the USFDA & SGS
Q: Do SMOKERHAVEN provide warranty?
Yes, 1 year warranty for all electronic component. Battery, Charger, PCC & Atomiser
Q: After 1 year what happen?
It’s just like handphone. Battery may wear out. We have replacement components/spare parts
Q: Can I buy spare parts?
Yes you can.
Q: Are there any discounts?
All prices are fixed at optimum price.
Q: Can I use the same cartridge for other models?
No. Only for SmokerHaven exclusive Electronic cigarette
Q: I have seen a model that uses liquid drops.
They are models from china. Very dangerous because it contains diethylene Glycol and the Nicotine is not controlled, regulated. You may get nicotine poisoning too. Our cartridges are approved by USFDA and are safe.
Q: What are the nicotine levels?
16miligram (High) 11 milligram (Low) 0 mg (None)
Q: What are the nicotine levels in real cigarette?
18mg for regular cigarettes 12mg for light
SmokeHaven starter kit RM310.oo, Cartridge pack of 5's RM15.oo. Great product Great Value. made in USA
feel free to contact me
call or sms 016 288 9960 mike
[email protected]
2 Batteries
1 Atomiser
Q: How to smoke?
Q: Is it safe?
Q: Why safe?
Yes you can.
[email protected]
