E-Cigarette *EXTREME PACK*
All Other Stuff
wildso80
New Health Care Product, Electronic Cigarette [EXTREME PACK]
The Electronic Cigarette is the all new alternative smoking solution that is taking the world by storm, using cutting edge technology from US country. E-Cigarette is an alternative cigarette which looks like a real cigarette, with the same taste and with a real smoke. Replaceable cigarette filter supplied.
Advantages of using this Healthcare Product:
* NO nicotine & tobacco content & NO air pollution (no CO2)
* NO fire, NO buring, NO tar and NO real smoke
* NO cancerous substances, NO ashtrays, NO butts, NO horrible smells
* Harmless for people around you, NO harmful passive smoking
* NO smelly mouth & NO yellow teeth anymore
EXTREME Pack includes:
* 1 x Electronic Cigarette Battery
* 1 x Atomizer (Heating element, MAXIMUM VAPORE KIND)
* 1 x Silver Grey Case
* 1 x USB Charger & Adaptor
* 1 x Car Charger
* 11 x Cartridge (refill type, NO Nicotine)
* User Manual
3 MonthsWarranty Period, 1 to 1 exchange ACCEPTED!!
** 100% COST Saving compile with REAL Cigarette (1x Cartridge = 10x REAL Cigarettes)
** HARI RAYA PROMOTION **
Selling RM88 ~ONLY
Normal selling price RM288
(*SPECIAL rate for postage fees per item, RM5.00 Penisular & RM8.00 Sabah,Sarawak )
Contact me:
016-330 8882
EXTRA Purchase of Refill cartridge is available here (WITH MEDIUM LEVEL NICOTINE 11mg).
Only RM10.00 for 10 pcs (normal selling price is RM25.00 & Above)
Available Flavor of refill cartridge:
Marlboro, Tobacco, Mild Seven, Camel, Mint, Hilton, Coffee, Strawberry, Apple & Mandarin.
NEW~ Dunhill, Gudang Garam, Mentol, Cigar & Vanilla.
Product Description:
Electronic cigarette is a sophisticated electronic device. In order to simulate the effect of smoking, we place a number of important microelectronic components into a small and thin stainless steel tubes like the shape of a cigar or cigarette.
At the end of the electronic cigarette tube is the pilot lights, which connect to a battery. The other end of thin tube is the cartridge. The cartridge’s holder is connected with the fluid chamber, which is the reservoir of electronic cigarette liquid.
Several more microelectronic devices, such as integrated control circuit, pneumatic sensor switch, and atomizer, is installed in the middle of the tube. All of this components is used to simulate the effects of smoking. Among those components, one end of control circuit is connected to a battery, and the other end is connected to the pneumatic sensors switches and atomizer.
There is a heating device in the atomizer. The heating device is connected to a pneumatic sensor switch and the reservoir fluid chamber.
Following along the E-cigarette thin tube, there is an air flow channel. It is easy to use E-Cigarette: This technology has its own unique, integrated control circuit, pneumatic sensor switch, and atomizer structure.
All of this components is required in order to ensure security of electronic cigarette pumping is easier and produce more considerable amount of smoke. Therefore, smoking with electronic cigarette is becoming more realistic feel. This technology has undergone many changes to our electronic cigarette from its dimensions to the internal structure since the first generation of electronic cigarettes.
FAQ :
What Should know when using this product. Important Notice:
- Do not place health cigarette fluid directly into mouth.
- Place the health cigarettes and all of it components in areas away from children.
- Once open the health cigarette fluid's packaging, the fluid should be consumed in two weeks.
- Remove the cartridge if you do not use the health cigarette for long time.
- The e-liquid, and cartridge should be placed in a cool and dry place. Avoid direct sunlight.
- Use only our company provided charger to charge your battery.
- Do not charge your battery under high-temperature or close to heat source.
- The lithium battery must be charged to 8 hours for the first time. After that, it only requires 2-3 hours of charging.
- Please pay attention to the polarity of the battery when charging your battery. Refer to the instruction manual for details.
- Do not use the charger for other types of batteries.
- Immediately stop using the battery if leak or any other abnormalities (smell, fever, discoloration, distortion, etc.) occurs.
- If the battery is not going to be used for long time, set aside the batteries from health cigarette or remove it from the charger.
- Charged battery shall be stored separately under low temperature and dry environment.
- This product contains micro-electronics components and sensors. It should be handled with care. and avoid shock.
- A real cigarette last about 12-15 mouthfuls of inhale. We strongly recommend that you take half an hour interval after 15 inhalation.
- For your safety and others, do not smoke health cigarettes while driving.
:slug:~HELP SAVE OUR ENVIRONMENT~:love:
:slug:~HELP SAVE OUR EARTH~:love:
Bro Xenith, can COD if you are at JB. I can do postage by POSLAJU for any outstation buyer.
---------- Post added at 07:24 PM ---------- 6 hour anti-bump limit - Previous post was at 07:24 PM ----------
Bro, do you do COD? I'm at TTDI, KL.
bro,
this e-cigarette still available? if so please pm me with the best price.. plus with refill pack.. thanks
