A
airtreking
Guest
To all you poor ppl :P
I have numberous feedback from professional tuners from England, U.S and Singapore about the problems with e-manage and the evo 4G63 and they all have the same conclusion. I quote from automotorsports, this is the link:
http://www.automotosports.com/EVO_stage_1.asp
"E-Manage is an inexpensive programmable fuel management system that allows you to properly tune your factory fuel system, without having to change the entire factory ECU system to an expensive "stand-alone" unit. The e-Manage system is a universal "piggy-back" type unit, which taps into most factory ECU wiring and it still utilizes the existing sensors. Basic functions will allow the user to slightly alter factory injector duty-cycle(± 20% at 5 preset RPM points), by intercepting and altering airflow or MAP sensor signals, but are only accessible though the use of our PC-Windows based "e-Manage Support Tool" communication software."
BUT!!!!!!:
"WARNING: After countless hours of dyno tuning it has been found that the additional timing harness for the greddy E-Manage is incompatible with the Evolution VIII ignition coils and may cause them to burn up, though you can still rely upon the E-Manage for advanced fuel tuning capabilities."
So dont let e-manage take control of the ignition....
Johan
BUT!!!!!!:
Johan
