Just to inform all the ZTH members that my friend have successful over-write rev cut for standard ECU using e-manage blue(1st gen).tested on nissan sr16ve,toyota 4age 20 valve,mit MIVEC,4g93.Just wana knw have any1 done it??
why do u need to overide revcut is u are not using highcam :hmmmm:
Rev cut by ecu work by cutting of fuel, e.g @7100rpm, it does not send signal/power to injector accordingly so, rev cut lor....
The concept"-
OVERRIDE by e-manage by is sending signal to injector after 7100 by using the sub injector section of e-manage- get the idea?
Additional diodes will be require since the wiring will be still using the original injectors...
If you do not do e-manage tuning by yourself, then better to get proffessional assistants...
