so if u driving alone.. then u stop by de road side.. suddenly some mother f**ker open ur door n pull u out n drive ur car away... can he still get away?
khguan,
that is the disadvantage of this simple immobilizer. You'll need to push the pushbutton switch in order to activate the immobilizer, where the engine will stop.
hey khguan,
this type of DiY car immobilizer doesn't use....don't everything also DiY.because if you want to DiY this item to your car,it's not worth if you lose your car...spend some money on safety system.you should know that car is our life...can't live without car so that other thing can DiY but security system please DON'T.
____________________________________________________this is my opinion,it's up to you....but GOOD LUCK.
halo all sifu out there..ive a problem...my car (satria neo campro) use haltech sprint500...change cable throtle..but still use ecu oem to control aircond and meter...I can not remove or raise the rev cut...now, my...
What are the main pros and cons of a single turbo and a twin turbo?
twin turbo are meant do make less turbo lag..
then what are the pros of using a single one?
is it true that a twin turbo is more suitable for those...
