lan evo 3,000 RPM Senior Member Joined Nov 24, 2003 Messages 3,076 Points 5,163 May 24, 2005 #1 just bought a set of defi is the oil temp and water temp sensor the same?
P phat7 2,000 RPM Senior Member Joined May 21, 2004 Messages 2,122 Points 3,148 May 24, 2005 #2 its the same buddy! You never bought meters? Both measure temperature thus similarity in sensors.
lan evo 3,000 RPM Senior Member Joined Nov 24, 2003 Messages 3,076 Points 5,163 May 24, 2005 #3 sure i bought the meter as well,but i found out one of the sensor bigger and longer a bit
cannondale> 1,500 RPM Senior Member Joined Apr 29, 2005 Messages 1,825 Points 5,138 Location kepong May 25, 2005 #4 both sensor are not the same.
lan evo 3,000 RPM Senior Member Joined Nov 24, 2003 Messages 3,076 Points 5,163 May 25, 2005 #5 cannon:then which one for water temp?
