There is no point raising a standard engine rev limiter,you are not getting more power instead the engine life will be shorter is keep revving above the std rev limit.The campro valve train is only design to safely operate at max 7000rpm.Revving above that is useless as the torque and power curve have dropped.It might be good for personal pleasure.It is best to change the intake/exhaust systems first before touching the ecu.Second is the camshaft,then get the ecu to be tuned with the mods done.
Full throttle shift is shifting without lifting the foot off the throttle pedal,but still need to press the clutch though,Unless using dogbox.
Unichip is same like e-manage,it's a piggyback system.
