- Joined
- Feb 21, 2006
- Messages
- 7,969
- Points
- 1,638
DREGO IMPORTS
T25/T28 -BRAND NEW
**6 MONTHS MANUFACTURER WARRANTY CARD**
T25 Flange, Dimension: 73 * 40
Oil Cooled, Inlet: M10*1.5, outlet: 2 M8
Max Power: 270hp, spool time at 2500 RPM
Compressor Wheel
0.42 A/R Cold Side
Ind: 37.8 mm
Exd: 59.7 mm
Trim: 40
Turbiner Wheel
5-Bolt Standard
0.86 A/R Hot Side
Ind: 52.9 mm
Exd: 45.47 mm
Trim: 73
25-27 PSI Power Performance Output
Internal wastegate at 8PSI
CNC Machined Flange
TDO5-H 16G EV03 Turbocharger
Condition - New
• 100% brand new. Never been tried or installed.
• Supports up to 360HP and deliver 580 CFM.
• Easy to install, Direct replacement to most DSM Applications.
• Type of Wastegate - Internal Wastegate
• Compressor Wheel - 48.3mm / 67.9mm Diameter
• Turbine Wheel - 49.2mm / 56mm Diameter
• No instructions included. Professional installation is highly recommended.
• Modification of turbo manifold might required to some application.
Applications:
• For All 4G63 2.0L Engine
Mitsubishi Eclipse GSX GST
• 91 / 92 Mitsubishi Galant VR-4 2.0L 98 Egale Talon 2.0L
6 Months Manufacturer Default Warranty
Price - RM 1400
TD05H 20G SUBARU
TD05H TURBO WRX/STI UNIT Utilize external wastegate Made of Quality Cast material Oil cooled & lubricated center section - journal bearing Suggested vehicle with1.6L to 2.5L engine: Up to 300-450bHP 3 Bolt Exhaust flange, 5 bolt downpipe flange All flanges pictured are included as well as internal wastegate
Turbo Specs:
Journal Bearing and oil cooled Inlet: 2 3/8", Outlet 1 5/8" Compressor :60 trim exducer 79.6 inducer 52 0.50 A/R Turbine: 77 trim exducer 49 inducer 50 N/A A/R
PRICE RM1600
GT28 T28 Turbocharger
Condition - New
• 100% BRAND NEW,REALLY HIGH QUALITY.
• THIS GT28 TURBO IS DIRECT BOLT ON UPGRADE FOR STOCK SR20DET/CA18DET TURBO.
• SIZE: 3.0" INLET,2.0'' OUTLET.
• COMPRESSOR:60 AR; EXDUCER:71.32MM; INDUCER:54.28MM.
• TURBINE :84 AR; EXDUCER:52.90MM; INDUCER:45.47MM
• TURBO MANIFOLD FLANGE: T25/T28 FLANGE; DOWNPIPE FLANGE: 240SX 5 BOLTS FLANGE.
• TYPE OF COOLING: OIL COOL ONLY.
• TYPE OF BEARING: WET FLOAT BEARING.
• SET AT 14.5 PSI AND CAN MAX UP TO 25 PSI,MAX UP TO 400HP
• NO INCLUDING INSTRUCTION. PROFESSIONAL INSTALLATION IS HIGHLY RECOMMENDED
Price - RM 1300
CT 26 Turbocharger
Condition - New
1988-1989 Toyota Celica All Trac 3sgte Engine Stock CT26 Turbo Replacement Turbocharger!!
Direct Bolt on Replcement for stock turbo.
Fully balanced wheel for best throttle response.
2.4" inlet for low back pressure.
Bronze bearing used for fast turbo spool & low friction.
High performance bronze thrust collar bearing used for low friction.
High performance cromoly oil ring's used for longer life expectancy.
100% Brand New.
Compressor Specs :
42.20mm minor
64.95mm major
CT26 Tubine Housing
Turbine Specs :
51.90mm minor
67.55mm major
Exhaust Outlet Flange with CT26 single scroll 4 bolt design
Price - RM 1500
GT15 T15 Turbocharger
Condition - New
Air Inlet 1.75"
Air Outlet 1.5"
Bearing Wet Floating Bearings
Wastegate 13PSI
Compressor .35 A/R
Compressor Compressor Wheel Exducer: 49mm, Inducer:36.4mm
Turbine Wheel Exducer: 34.95mm, Inducer:41.35mm
Works for:Perfect for Small Engine, 2-4 Cylinder.
Price - RM 1200
DEALER WELCOME
DREGO IMPORTS (001990983-A)
GPS: 3.073991,101.61681
DREGO IMPORTS
No.6-M, Jalan PJS 7/20B,
Bandar Sunway,
46150 Petaling Jaya
Selangor, Malaysia
[email protected]
MOB : +60123505832
OFFICE :0356361481
T25/T28 -BRAND NEW
Compressor Wheel
0.42 A/R Cold Side
Ind: 37.8 mm
Exd: 59.7 mm
Trim: 40
Turbiner Wheel
5-Bolt Standard
0.86 A/R Hot Side
Ind: 52.9 mm
Exd: 45.47 mm
Trim: 73
CNC Machined Flange
Condition - New
Applications:
Price - RM 1400
TD05H 20G SUBARU
Turbo Specs:
PRICE RM1600
Condition - New
Price - RM 1300
CT 26 Turbocharger
Condition - New
100% Brand New.
Compressor Specs :
42.20mm minor
64.95mm major
CT26 Tubine Housing
Turbine Specs :
51.90mm minor
67.55mm major
Price - RM 1500
Condition - New
Air Inlet 1.75"
Air Outlet 1.5"
Wastegate 13PSI
Compressor .35 A/R
Price - RM 1200
DEALER WELCOME
DREGO IMPORTS
Bandar Sunway,
46150 Petaling Jaya
Selangor, Malaysia
[email protected]
MOB : +60123505832
OFFICE :0356361481
