Need advice on Crossovers
Guys,
Have a component set. Unfortunately, the crossover does not have any indications of input, mid, bass or tweeter. How do I determine which goes where? Is there a way?
Is it possible for me to just try it with the sound on? Will swapping the cables here and there on the crossover with the music on spoil the crossover?
I have a 45W X 4 head unit. I have read about parallel and serial connections and the effects of the Ohms and etc. However, I do not really understand how the crossover effects the Ohm or Wattage of speakers.
If I use a crossover with a 4 ohm Midbass and a 4 ohm tweeter, is the total ohm for that component system, 4 ohm?
Can I connect 2 tweeters (4 ohm each) to the same crossover (Tweeter output) and 1 Midbass (4 ohm)? Will the wattage be cut in this case? Will the total ohms decrease or increase?
Please, sifus... Help me! I'd really appreciate it! :X-:
Guys,
