Cefiro Club
ongteckweng said:
bobby....honestly speaking...its hard to get VQ35DE for less than rm10k coz its pretty new in Japan.
maybe will scout for u an A33 VQ30DE...should be cheaper...
Thanks David....hope to hear some good news fr you soon....
....If you go to chop shop, can also ask if they willing to bring in the half cut if I pay them some deposit....but I hope they won't jack up the price if we show too much interest like that....
You think I can save some money if just look for the engine??...don't know how much for engine kosong & gear box ??
whats obit ecu gary? mind to share?
bobby...will try my best...but dont give so much hope...
there is another way...buy vq30de from anyone who is changing to vq25de...its a lot cheaper for sure...
however, its not recommended by installaing the engine n g/box without the wiring n ecu...all vq series engines have diff wiring system n ecu...so ur 2.0 system will not be compatible with 3.0...it will starts but in long run, u will develop probs...
RachelAgl said:
David,....I am a bit itchy to up-grade to 3.0 or 3.5L if not too expensive...must check the price first...you know I lost a fortune last 2 months...:cry_smile:
DET engine is turbo,right??...actually I don't quite like turbo engine...
...if available VQ35DE should be alright...how much it's going to cost with the 6 speed gear box??...do check for me the price if u have the time...thanks!!
Initially I was thinking to try get the whole half cut so I can also change the meters (nicer),steering (half wooden? +cruise control),anti-glare rear mirror,etc...but I doubt I can get it below 10k....
Let's see what your fren can find for me and the price then only decide...
Well, if can get a half cut Infiniti I35 will be just good....
http://www.autobuyguide.com/2003/12-aut/infiniti/i35/specifications/index.html
O-BIT Piggy Back ECU.
The O-BIT is a Subcon (Piggyback) which is very near to a Stand-alone system.
O-BIT outperforms current Piggyback systems with additional new functions such as fuel control using O2 signal, automatic tuning mode, shift lamp control, fan switch control, Nos control, water injector control, data logging for 48houre, Drive history for 48days. Additional injector control, a boost control, speed limit control etc.
The application is versatile regardless of type of engine and year model of cars. Especially automatic fuel adjusting by O2 sensor signal is very unique and unavailable to other piggyback system other than standalone ECUs (the price of a unit is very high although there is this function).
O-BIT is piggyback system has same function as a stand-alone ECU. This function (self-controlled fuel adjust) play very important roll for using piggyback with original ECU. Cars in recent years are always supervising the signal of O2 sensor, and this O2 signal is the signal adjusting fuel and ignition time. It is impossible to effectively tune an engine with an ECU without this auto-tune function that O-Bit uses.
So in short, about the same as MAP ECU.:regular_smile:
Dreamo.. how much u brought ur Map Ecu? Can U let me know the add which u get ur tein at subang 2??
PLan to get 1 abs..
My fren's Obit ecu wan to sell.. dono should take or not.. how bout unichip is it same?
Hi JoeBlack...
If you are talking about VQ20DE vs RB20DE, I can only say VQ20DE runs smoother comparing RB20DE. In terms of power....I have not check spec to spec which has more BHP and Torque.
V6 will rev smoother and I6 can rev hard!!
In general, VQ is a V6 and RB is inline 6....
Both engines are choice powerplant for Sport Sedan or larger build saloon.
http://en.wikipedia.org/wiki/Nissan_VQ_engine
http://en.wikipedia.org/wiki/Nissan_RB_engine
JoeBlack said:
is the VQ more powerful than the RB does it come in turbo?
PLan to get 1 abs..
Hi Gary, The MAP ECU is about USD 620~700 now. Can buy online.
http://www.zerotohundred.com/newforums/www.performancemotorresearch.co.nz
This is the original product owner...there are alot of reseller..just Google MAP ECU will do.
As for the TEIN, you sure you want to go for this product? i can tell, most of the member in our group think that my ride is on the hard side....no more comfy loh!
Only thing is tat you can do Zig Zag in a 3 lane highway while driving 160km/h...hhh but why would you want that?
The Subang 2 shop is like SMI type. Very confusing place..
You can go in via subang Terminal 3 or can go via bukit jelutong shah alam.
I'll try to draw you a MAP...i'll try to recall.
If you are free, i can meet up with you and go in during weekend too. I need to replace my rear abs's bushing too.
As for O-BIT, i get to know from my friend that it is actually from PerfectPower http://www.perfectpower.com/ but brand under another name. It's from South Africa.
I believe it's about the same as UniChip. Piggy back still Piggy back, you can only play with a few things...Fuel MAP, AFM MAP, Lamba or O2 feed back processing.
I suggest that you look for someone that can give you a one stop shop solution.
Avionics Enterprise (M) Sdn Bhd. 603 7803 3263 [email protected]
GT Auto Service Sdn Bhd 012-2125840 [email protected]
Above two company reselling PerfectPower. Suggest you call up and check with them if they can do end to end for you.
Else, go for RSI. http://www.rsimpressive.com/ in Puchong. I did it over there. and they carry UniChip.
http://www.geocities.com/robyndigital/
Ong san.. Thanx man.. they sale other brand too?? or just tein only.. i work full day at sat lehh.. sunday i don think so they open loh..
PLan to get 1 abs..
gary...dreamo's tein its a bit hard for normal usage unless u travel a lot on high speed like dream :evil:, then its not recommended...with the road condition in JB, u will curse n swear...:biggrin:
if u r looking for straight foward power upgrade, why dont u just change to VQ25DE!! in terms of engine power n top speed, it will beat ur stock VQ20DE for sure...its relatively cheaper in terms of power gain...think about it...:evil:
rival said:
Dreamtent san,
My buddy here got ask GAB hard/soft , adjustable RM 2100 including installation. it's a new set. is it worth to install >?
hahaha i'm using GAB adjustable .. hi / lo ... damn hard man ....
Ong San.. my side here cannot get leh.. ask them to order. dono how many months already the bulb not here yet..
Maybank2U the money and get someone PostLaju back to you loh... simple.
huh...white bulb its very common stuffs wor...im sure they stock it...
anyway, why u wanna change to white la? make ppl confuse when u turn them on...:biggrin:
