Braking issue
lukel95
75
28
GB birmigham
Hi guys, recently if i full lock to the left and then brake whilst reversing my brakes make a very loud sort of trumpet sound, any ideas?
Sent from my SM-G935F using Tapatalk
g4i8y0t
1,216
330
683
Kedah
Do you left your car in the rain or just recently washed it? If yes, it's just the sound of your disc/brake pad squeaking, which is normal.
lukel95
75
28
GB birmigham
Yeah it mainly does it after being in wet conditions or after washing so I did think today that could be the cause
If disc rust then no need full turn will have sound also......:smokin:
mag9556
2,770
43
1,648
or your brake pad no more already.. some cars pad finish uneven.. if new brake pad the rust after water splash (as above mentioned)..
lukel95
75
28
GB birmigham
Also when I brake coming to a stop sometimes I'll hear a scratching noise and if going down hill, the noise will sometimes continue after braking, would that be a sticking caliper?
Could be sand trapped in between, or your pads near finish the indicator touching the disc?:smokin:
i just had my battery relocated to the trunk and i could not be sure whether this had caused me electrical unstablity because im noticing small bouncing rpm when signal light is on during idle, the vacuum meter dims when headlight and signal is switched on
my car is not super audio equipped, only brighter PIAA headlamp, and the meter. i have 2 stabilizers and problem still persists
i just talked to a friend who told me i need to get a grounding wire from alternator all the way to...
