*.bin file format
FuGZ
Random
i downloaded a file... it's a *.bin format... what do i use to open this file? WinRAR can't, nor Nero... it's a 500+ MB file...
Please help me out, thanks...
U need the cue sheet. Usually a .cue file.
If you dont have it, you can still use Nero
In Nero, go to File -> Burn Image.
Find the *.bin file that you want to burn and open it. Then you'll get a window that says: "Foreign image settings"
These are the settings:
Type of image: leave that unchanged to Data Mode 1;
Then, very important, select the Raw Data check box. When you do that the Block Size (which is one line below) changes automatically from 2048 to 2352.
That's all! Leave Image Header and Image Trailer unchanged and set to 0. "Scrambled" and "Swapped" check boxes should remain UNchecked as well.
if not mistaken can mount .bin files
can use the nero image drive
or like daemon-tools.
http://www.daemon-tools.cc/dtcc/portal/index.php
