Automatic Transmision Oil Cooler
kent20
Last unit Crazy Sales!~
Stock Ready!!!!!!!
Big(677)=Rm220 first come firsr serv
Full Package Including Kit
Full Package in box Including:
1xHydraulic/pressure Hoses
4xmounting/stopper
1xcooler
4xclamps
HAYDEN Rapid-Cool® Automatic Transmission Oil Cooler Kit:
Compare 7UP,676 & 677
Model:676&677
Made in Australia
  • Cold down the Transmission oil
  • better respond
  • long life usage for transmission oil
  • Good for long term traveler driver
Rapid-Cool® Transmission Oil Coolers
Rapid-Cool®’s unique plate and fin design offers excellent cooling efficiency in a compact, space-efficient design. Features
  • 33% more efficient than a comparable tube and fin design
  • Pre-drilled mounting plates for easy installation
  • Four sizes available to fit a wider range of applications
  • Internal turbulation for efficient heat transfer
  • 3/8” push-on fittings for quick and easy installation
Engages at about 170° radiator air temperature, (about 30° lower than coolant temperature).
This Cooler can be use as Engine oil Cooler
Engine Oil Coolers will protect your engine from overheating,
But will not correct a faulty engine.
The mechanical condition of the engine should be checked by a competent mechanic prior to installation if troubles are suspected.
Last few unit Crazy Sales!~
Small(676)=Rm200 Size=280mm x 110mm x 19mm(last 1unit)
Please Call 012-2023765
(kent)
Kent, please kindly take your own photo for posting purpose...Thx !!
ops sorry didn't know that is you picture,I get the picture from my customer,because i didnt see any water mark so i use it,zth still under-mention,i cant delete the picture that i upload to zth,i will pm tom to remove it thanks
p/s:Water mark your picture next time so other people can avoid to use your picture thanks
Bro!The cooler's material is iron? Alloy? or Aluminum?
Thanks
last one unit Rm200 012-2023765 call me any time
last unit leave
012-2023765
