- Joined
- Feb 18, 2005
- Messages
- 4,448
- Points
- 3,138
Last unit Crazy Sales!~
Stock Ready!!!!!!!
Big(677)=Rm220 first come firsr serv
Full Package Including Kit
Full Package in box Including:
1xHydraulic/pressure Hoses
4xmounting/stopper
1xcooler
4xclamps
HAYDEN Rapid-Cool® Automatic Transmission Oil Cooler Kit:
Compare 7UP,676 & 677
Model:676&677
Made in Australia
Rapid-Cool®’s unique plate and fin design offers excellent cooling efficiency in a compact, space-efficient design. Features
This Cooler can be use as Engine oil Cooler
Engine Oil Coolers will protect your engine from overheating,
But will not correct a faulty engine.
The mechanical condition of the engine should be checked by a competent mechanic prior to installation if troubles are suspected.
Last few unit Crazy Sales!~
Small(676)=Rm200 Size=280mm x 110mm x 19mm(last 1unit)
Please Call 012-2023765(kent)
Stock Ready!!!!!!!
4xmounting/stopper
1xcooler
4xclamps
Model:676&677
Made in Australia
- Cold down the Transmission oil
- better respond
- long life usage for transmission oil
- Good for long term traveler driver
- 33% more efficient than a comparable tube and fin design
- Pre-drilled mounting plates for easy installation
- Four sizes available to fit a wider range of applications
- Internal turbulation for efficient heat transfer
- 3/8” push-on fittings for quick and easy installation
share your experience hehehe
