J jamis Junior Member Senior Member Joined Dec 2, 2003 Messages 22 Points 3,003 Oct 11, 2004 #1 my saga with 4g13 can mati engine wats the prob??
P polyxtroy Known Member Senior Member Joined Feb 18, 2004 Messages 347 Points 5,018 Oct 11, 2004 #2 4G13 auto... ada meh?????
J jamis Junior Member Senior Member Joined Dec 2, 2003 Messages 22 Points 3,003 Oct 11, 2004 #3 tat one is new engine. my dad chang the gear box as well
g88 3,000 RPM Senior Member Joined Jan 28, 2004 Messages 3,082 Points 5,148 Oct 14, 2004 #4 can explain more in what case engine died off ?
D DJmobile 500 RPM Senior Member Joined Dec 13, 2003 Messages 965 Points 3,018 Oct 14, 2004 #5 most often cases.. i think is 1 spark plug spoil liao... happen to my uncle b4... change spark plug then ok liao...
J jamis Junior Member Senior Member Joined Dec 2, 2003 Messages 22 Points 3,003 Oct 21, 2004 #6 my spark plug jus changed... when accelerate either backward or forward. Especially on the pick up.
g88 3,000 RPM Senior Member Joined Jan 28, 2004 Messages 3,082 Points 5,148 Oct 21, 2004 #7 check your carb, fuel pump, distributor
H hyperlemon Active Member Senior Member Joined Aug 3, 2004 Messages 42 Points 3,006 Oct 21, 2004 #8 4G13got auto de??? like this the fc r very high lo
J jamis Junior Member Senior Member Joined Dec 2, 2003 Messages 22 Points 3,003 Oct 22, 2004 #9 fc? fuel consumption? not really leh, aft pasang one airfilter abit kuat the fc, if go n blow kuat kuat fc also kuat kuat
