http://images.leonardfoong.multiply.com/image/1/photos/8/600x600/1.jpg http://images.leonardfoong.multiply.com/image/1/photos/8/600x600/3.jpg http://images.leonardfoong.multiply.com/image/1/photos/8/600x600/5.jpg
http://images.leonardfoong.multiply.com/image/1/photos/8/600x600/7.jpg http://images.leonardfoong.multiply.com/image/1/photos/8/600x600/9.jpg http://images.leonardfoong.multiply.com/image/1/photos/8/600x600/11.jpg
http://images.leonardfoong.multiply.com/image/1/photos/8/600x600/13.jpg http://images.leonardfoong.multiply.com/image/1/photos/8/600x600/15.jpg http://images.leonardfoong.multiply.com/image/1/photos/8/600x600/17.jpg
Specification
Body
Two door coupe or convertible body style with 2+2 seating
Extruded aluminium bonded body structure
Aluminium and composite body panels
Extruded aluminium door side impact beams
Xenon gas discharge projector headlights (dipped beam), halogen projector headlights (main beam) with power wash
LED rear lights
Engine
All alloy, quad overhead camshaft, 48-valve, 5935cc 60° V12
Mid-front mounted, rear wheel drive
Engine management system with Neural Net misfire detection system
Fully catalysed stainless steel exhaust system with active by-pass valves
Compression ratio 10.3:1
Maximum power 335 kW (450 bhp) at 6000 rpm
Maximum torque 570 Nm (420 lb ft) at 5000 rpm
Acceleration (Coupe manual) 0-60 mph in 4.7 seconds 0-100 km/h in 4.9 seconds
Acceleration (Coupe automatic) 0-60 mph in 4.9 seconds 0-100 km/h in 5.1 seconds
Maximum speed 186 mph (300 km/h)
Transmission
Rear mid-mounted 'Touchtronic 2' six-speed gearbox with electronic shift-by-wire control system
Rear mid-mounted six-speed manual gearbox
Limited slip differential
Final drive ratio 3.07:1 (auto) 3.54:1 (manual)
Steering
Rack and pinion, Servotronic speed-sensitive power-assisted steering, 3.0 turns lock to lock Column tilt and reach adjustment
Suspension
Front: Independent double aluminium wishbones incorporating anti-dive geometry, coil over aluminium monotube dampers and anti-roll bar
Rear: Independent double aluminium wishbones incorporating longitudinal control arms, coil over aluminium monotube dampers and anti-roll bar.
For sale... Anyone interested, PM me...
Specification
Body
LED rear lights
Engine
Transmission
Steering
Suspension
